Question about Dell Inspiron 1100 Notebook
Line on laptop display - Dell Inspiron 1100 Notebook
  • Dell Master
  • 1,183 Answers
The line on the display is generally caused by a bad LCD inverter cable and generally requires a replacement of the LCD.
Connect an external monitor to the laptop , Tap Fn+ F8 key to toggle the display to the external display. If the picture on the external display looks good you need to replace the LCD kit
If the display also has a line , the problem is with the motherboard
Thanks for using Fixya
Proton
Posted on Oct 13, 2010
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
Aug 17, 2015 | Dell Computers & Internet
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Multicolor lines on laptop display
multicolor lines on laptop displays means that you have a defective LCD DISPLAY.
Jul 14, 2011 | Computers & Internet
Jst a few months back i had bought dell inspiron laptop n it was working on very well but suddely i got to a vertical green line on the right hand side of my laptop screen.... could you please tell me the...
You should have a video plug on the side of your laptop. It might be a 9 pin plug or a 15 pin plug. You can attach an external monitor or LCD monitor to this plug. If the green line displays on the external monitor then your video circuit on your laptop is faulty. If the line is not present on external display then your laptop LCD display panel is defective.
Jan 09, 2011 | Dell Computers & Internet
Vertical colored lines have appeared in my display.
turn on the system by pressing FN key and then the power but this should start up the onboard diagnostics let me know if the line are displayed during the diagnostic if it does the its the graphics. when it ask you if vertical or horizontal bars were displayed. select N so it can test the LCD panel if the lines are displayed there then it is your lcd panel.To make sureyour lcd panel is fine it will display solid colors.
Jan 20, 2010 | Dell Latitude D510 Notebook
My laptop screen has a thin blue line going down, why has this happened?
You have the beginning of a failing Display panel, and will eventually need to replace the display.. you can hold the top left and right sides of the display screen-slightly bend forward and back, you should see the blue line either go away or it will produce more lines...
This is due to a short on the circuit board panel on the backside of the display panel that controls the Pixels on the Screen.. The Pixels are controlled In a Line Grid Fashion...
Nov 16, 2009 | Dell Inspiron E1505 Notebook
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
Display on laptop
Have you tried plugging in an external monitor to see if the display is ok. I suspect you will find external display is perfect and only the LCD on the laptop is affected.
I have a laptop that the "tab" welds are not connecting properly on the lcd and 1/3 of the display is multiple lines or black. Pressing on the top of the lcd changes the colors on the display but does not fix the problem, I had to replace the lcd.
Mar 23, 2008 | Intel Motherboard
Dell Inspiron 1100 Notebook Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
