Question about Whirlpool Washing Machines
I have a Whirlpool "Ultimate Care" top loader washer, bought approximately 1999. Recently, the cold water supply only trickles into the drum when using WARM or COLD water selections.
  • 5,911 Answers
This is a symptom of a water inlet valve problem. Probably the cold water solenoid. To replace, follow this link:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Please let me know if this is helpful to you. If you have further questions, please post back on my profile by using the "Ask Me" feature.
Posted on Jun 01, 2008
  • Whirlpool Master
  • 19,396 Answers
I think you should test the programme panel first , if it is not this is the inlet valve.
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
On demand, the cold water comes only trickling in. Hot is just fine.
If you turn off the water supply and switch the hot and cold hoses see if the problem the cold cycle is only trickling hot water. If the problem switches order a water inlet valve which is about $20.00. To replace the valve turn off the water and unplug the unit. Pull the unit out and remove the back panel. Disconnect the hoses from the valve and unplug the connecter. Replace the valve and plug in the connector reconnection all the hoses. Test the unit before closing it up.
Feb 21, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The cold water trickles. There is a "good" flow of water (hot&cold) to the machine yet, the cold water trickles out on any cold setting. The hot water has great flow. What could be the answer?
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR8233EQ0 Hot water (only) trickles
you need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Water fills to wash, but trickles when rinses
you can try cleaning the filter at hose end, where it hooks into the unit.make sure your cold awater supply is good.
Apr 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
