Question about Brother CS-100-T Computerized Sewing Machine
My bober winder is not moving - Brother CS-100-T Computerized Sewing Machine
How do you do the brother bobbering x
Posted on Oct 24, 2010
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
BOBBIN WINDER WILL NOT MOVE,I CHANGED THE SMALL BELT IT IS STILL FROZEN.
If thye winder will not move at all then the chances are it may be seized through lack of oil, you can take an electric drill and put it over the winder pin but put some WD40 on the winder pin first then turn the drill on slowly and it should free off, watch for splashes of oil.
Apr 25, 2010 | Sewing Machines
I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Feb 24, 2010 | Singer Sewing Machines
The motor runs but NOTHING moves, not even the bobbin winder
If the motor is actually running but nothing moving at all even the winder then either the belt is loose or it has come off.
Nov 06, 2009 | Brother XL-2600I
I have a Viking Husqvarna and it seems that the bobbin winder won't disengage. when you press the pedal down the needle doesn't move but you can hear the bobbin spinning but when you put a bobbin on the...
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
Nov 05, 2009 | Husqvarna Viking 1
Help with threading the machine from the spool of thread
some have self bober thread load empty one a hit hred bobber
May 15, 2009 | Sewing Machines
Brother CS-100-T Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
