Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpoolfront load duet washing machine
It is not draining i think becouse there is still water at the bottom and clothes are realy wet. i tried drain and spin i triedrince and spin and starting the whole cycle over it said suds at one point thats why i tried rince and spin but none of that would do anything it also flashed f2 what ever thay means i can't find my dvd or manuel now it won't let me even open the door my kids school clothes are in there and they have school in the morning please help!!!!!!
  • 5,911 Answers
"F02" is a Long Drain error. This could be caused by a number of things. The likely suspect is your drain pump. Please click on the following link for instructions on how to diagnose and repair this problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information helps you. Please post back if you need further advice. Go to my profile and use the "Ask Me" feature for a quicker reply.
Posted on Jun 01, 2008
What does FP mean?
Try looking online for another manual. Or call anyone who sells your machine. Me thinks the solution is simple, but you need to talk to any seller of your machine, and soon.
Mar 04, 2018 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stopped with a wet load of clothesin the washer. This would be the rinse cycle
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: F35 keeps flashing clothes are wet, when I turn of...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer & the clothes will not spin out the water when the washer is done they are still soaking wet?
possible that with the machine not draining, its not going to high speed spin try this:
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't stop draining water
To take your clothes out,just unplug machine's power cable and you should be able to open the door. Why do you think that your "machine thinks that there is still water inside it when there isn't" ?
Sep 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
