Question about Altec Lansing 2100 Computer Speakers
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no audio devices installed.... speakers altec lansing 2100
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 13, 2010
I have a 2002 holden rodeo 3ltr turbo diesel that just stopped while driving how do you check to see if it is the pump or just blocked lines
Just to start with the basics make sure their is fuel in it ... somtimes when these trucks run out of fuel you have to add more then 5 gallons to get the fuel high enough to run over the internal cup that the fuel pick up tube sets in 1 or 2 gallons is not enough to do this . Then have some one try starting the truck while you remove the fuel cap and put your ear to the fill tube for the gasoline you should be able to hear the fuel pump run because it is located inside the fuel tank . If you don't hear the pump running you can try hitting the bottom center of the fuel tank with a heavey blunt object ( block of wood ,Baseball bat ect.) nothing that has a sharp edge . Do this while some one is cranking ( turning the key to start the truck) this somtimes will free the pump up and it will start working again . If it starts then you know the pump is bad . Somtimes when the pump frees up they work again for weeks or months but it not good to take that chance and break down on the highway. Replace the pump and filter .
Aug 05, 2012 | Isuzu Rodeo Cars & Trucks
I am using nokia 1600 mobile with an airtel connection suddenlly sms sending stopped and i have checked all thing message center no and all but its not helpfull att all and thhe sim working in other...
try to turn off the phone, remove the battery, make sure sim is placed currently, keep battery out for 30-60 seconds, put battery back and turn on phone should work. if it's still giving you a hard time, check the capacity on your phone maybe it's backed-up
Dec 09, 2010 | Nokia 1600 Cellular Phone
I cant hear anything without earphones
If you have left the earphone plugged in to the laptop for a long time, this may have bent the contacts in the socket, and stopped the speakers from working.
Apr 09, 2010 | Microsoft Windows XP Professional
The sound suddenlly stopped working on our vizo tv, what do we do
Check ya haven't accidentally pressed the "MUTE" button, just an idea?
Jan 19, 2010 | Vizio L37 Television
All buttons suddenlly stopped work correctly.
must be check if it exposed to any sort of liquid and if not remove the memory card and try to do software
May 11, 2009 | Nokia 6500 Slide Cellular Phone
My webcam has stopped working
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Sep 13, 2008 | Computers & Internet
Power on green light is on but no sound when speakers are hooked up
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Luda
Jul 04, 2008 | Jl Audio Car Audio & Video
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
My Touch pad does not work, can someone help? the touchpad suddenlly stops working while i was using it
try to remove battery. Turn on you computer without battery. battery can cause keyboard and mouse not working.
also make sure your touchpad is enable by using fn+F7
if this is still doesn't work, it's mean your touchpad itself is bad.
Apr 09, 2008 | Acer Aspire 3680 Laptop
Sound Shut Off
i understood your problem...u cannt hear sound after listening for 30 min continuosly..so best way is listen songs for 28 min and shut down ur computer and again turn it on...thus can listen for 28 min more..do this as long as u wish to listen songs..
do remember,,,no gains,,no pains...
Jan 07, 2008 | Logitech X-540 Computer Speakers
Altec Lansing 2100 Computer Speakers Logo
230 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
