Question about Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White
We recently moved & our Maytag fridge (model#MFI2569VEW) is runnign very cold. the in the door compartment section on the right hand door is where we normally put milk, etc to keep a little extra cold... The milk & other products from the bottom shelf are freezing solid (especially items in the door compartments)... As you move up on the shelves then it gets warmer- at no point is the fridge "warm" though. We normally keep ther firdge at the recommended 38 degrees, but have tried raisinhg the fridge temp to fix the freezing issues, but that hasn't helped. Currently even itemss in the fruit & vegetable drawers freezes also... How can I fix this?....
  • 106 Answers
SOURCE: bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Posted on Jan 11, 2008
SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Posted on Mar 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
appliancepartsse@yahoo.com
Posted on Jul 20, 2009
SOURCE: vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Posted on Jan 07, 2010
Sea Breeze
  • 4655 Answers
SOURCE: food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Posted on Jan 20, 2010
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
MFI2569VEW water/ice and controls cycle off then on every 15-20 minutes
You need the control board on the back of your refrigerator. This was a problem back when they first come out with this model. Call Maytag and see if you can get a concessions for repair.
Dec 30, 2017 | Refrigerators
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Samsung freezes but not cooling
You need to post the model of the fridge for precise answers. In general, all refrigerators work by making the freezer section very cold and then opening/closing vent doors to blow some of that cold into the fridge compartment. There is a thermostat in the fridge section that opens the vent door when things need to be cooler, closes the door when cool enough. Look for that door and see that it works and make sure the blower is running and door vent not blocked (or frozen shut).
Feb 11, 2015 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I have a Maytag Stainless Steel Fridge side by side 10 month old, freezer works fine fridge warm as death! Freezing lower cold air vent between the two drawers. Model MSD 225 8AE SO1 Serial...
i couldn't look up your machine,maybe bad model number,i would call the factory,it's under waranty for the first year,you either left the door open or you have a defrost problem,let me know if you're gonna call the factory or if you want to fix it yourself,if you want to repair it let me know and check the model number inside the fridge section on the right hand wall up near the ceiling
Sep 22, 2010 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White Logo
118 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
