Question about Kenmore Washing Machines
Model 110.27062602 admits small amount of water and immediately goes into the spin cycle.
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Oct 13, 2010
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
How do I drain all the water from the drum?
Depends, on model but all will drain if you disconnect the tub to pump hose. Do not confused liquid manufactured into the bowl for balancing on spin with a small amount of water left in the outer bowl when the cycle is finished.
Dec 21, 2013 | Washing Machines
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine starts to fill then stops and beeps
try it on rinse cycle if goes ok then the hot water valve is faulty
Dec 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
