Question about Husqvarna Chain Saw 20" Bar
I can't get the grease gun to work for the bearing lubricant. Is there something I need to know?
  • 7,733 Answers
It is better to replace the bearing.
Posted on Oct 13, 2010
What grease or oil do i need to lubricate the bearings and wobble plate on my Karcher pressure washer.
Use a Teflon based grease. Contact an auto parts store to buy it. The grease is usually colored blue.
Jul 16, 2016 | Karcher Garden
My honda harmony II model number HRR2168VYA rear wheel won't turn backwards, they move forwards just fine.
If you remove the wheels, there are little keys under spring pressure. The grease lubricating them hardens over time. Clean this out with toothpicks and brake cleaner, reassemble with some wheel bearing grease or grease from a lube gun, and it should work just fine, otherwise maybe the trans has a problem.
Jul 09, 2016 | Honda Garden
Have a squeezing in the front left tire only when turning left and pushing the gas in a 95 ford escort
your front suspension has ball joints which have a lubrication adapter that takes ball bearing grease. you need a grease gun. better to take it to a shade tree mechanic and let him grease all the front end joints. get a quote on the cost first.
Mar 08, 2014 | 2003 Ford Taurus
Proform ZE3 Elyptical screeches constantly
FOLLOW THIS STEPS AND FIX IT. God bless you Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Mar 22, 2013 | Exercise & Fitness
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
Pedal tention too tight
Step 1:
please proceed with this step . Happy new year and God bless you
Lubrication
Step 2:
Pedal Arms
Step 3:
Link Arms
Jan 01, 2013 | Exercise & Fitness
My proform spacesaver 500 eliptical is making a clicking sound
follow this steps and fix it. God bless you
Lubrication
Link Arms
Pedal Arms
Nov 30, 2012 | Exercise & Fitness
Pedals are locked won't spin foward but will spin backward
see the following steps, and fix it. God bless you
Pedal Arms
Nov 28, 2012 | Nautilus R514 Recumbent Bike
Noise from bearings
see this steps and fix it. God bless you
Pedal Arms 1
Link Arms 1
Lubrication 1
Oct 15, 2012 | Proform Pro Form Sears Elliptical Drive...
The pedals on my Nordic Track SL700 turn completely free. I think I need to replace the crank assembly but cannot seem to get into it. Is this bike worth the price of a new crank assembly part?
Dear Sir:
Please do the following:
Use aflat screwdriver to unseat the tabs that hold the front top cover in place.This will expose the flywheel and pedal arm connection points. Rotate theflywheel by hand and determine whether lubrication will accomplish the repairs.If the bearings are exposed, use a grease gun with an extension nozzle and lubricateboth bearings with lithium grease. If the bearings are damaged or sealed,proceed to the next step.2
Removethe front and side covers on the main frame. Hold the flywheel with one handand use a box wrench to loosen the bolts that secure the pedal arms at eachside of the flywheel. Pull the arms away from the flywheel and remove thebearings from each side.3
Test thebearings as before. Lubricate exposed bearings with lithium grease andreinstall them. Sealed bearings must be replaced. Reattach the pedal arms tothe flywheel. Replace the main frame covers and front top cover to complete therepairs.sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 09, 2012 | Exercise & Fitness
Husqvarna Chain Saw 20" Bar Logo
142 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
