Question about Sharp AL-1457 Black and White Copier
Copier displays H4 error code and would not copy
    Guru:
  • 452 Answers
Detail for error code H4: Fusing section low temperature trouble
•The set temperature is not reached within the specified time (normally 3 min) when warming up or resetting from pre-heating. Cause:
  1. Cause thermistor trouble
  2. Heater lamp trouble
  3. Control PWB trouble
  4. Thermostat trouble
  5. AC power trouble
  6. Interlock switch trouble
Solution:
  • If the heater lamp blinks normally:
  1. Check the thermistor and its harness.
  2. Check the thermistor input circuit in the
  3. control PWB.
  • If the heater lamp does not light:
  1. Check for heater lamp disconnection and
  2. thermostat disconnection.
  3. Check the interlock switch.
  4. Check the AC PWB and the lamp control
  5. circuit in the control PWB.
good luck
Posted on Oct 13, 2010
  • 208 Answers
SOURCE: Toshiba e-studo120 H4 error code
This should do it.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 20, 2007
Cogz
  • 1326 Answers
SOURCE: error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Posted on Feb 18, 2008
Opelmanz
  • 62 Answers
SOURCE: SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Posted on Nov 02, 2008
  • 990 Answers
SOURCE: code H4 comes up when the sharp copier ar-5316 is switched on
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Posted on Jan 28, 2009
  • 10 Answers
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
Posted on May 19, 2009
Error code H4
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
What does an error code H4-01 mean on a Sharp MX4501N copier? The machine no longer copies, simply displays: Call for service Code H4-01.
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
WheatlandServices
Nov 13, 2010 | Sharp Copier Cabinet Printer
What does 4 H indicate?
When your copier voltage is abnormal then heater lamp is not on properly.So indicate H4.When H4 signal is blinking you must reset this code or error.
press c button press Photo/Exposure button again C Photo.(C>Photo>C>Photo) display blank press copy quantity button 14 press print key /Start key machine will be ready.
All are hopes fix
Dec 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Error code H4 on Sharp AL-1641CS?
Usually a flase code on these models. Try clearing by pressing "C" then far left key (Exposure Mode) then "C" then far left again. Must be pressed quickly and if done correctly display will go blank. Then key in 14 as if making 14 copies. Then press Print.
Short Version: C, far left, C, far left, 14, print
If code returns then you have a fusing unit problem but 9 times out of 10 this is just a false code.
Good Luck
Dec 23, 2009 | Sharp AL-1642CS Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Sharp AL-1457 Black and White Copier Logo
208 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
