Question about GE Washing Machines
I have GE Model WWA7678MALWH washing machine. I cannot get it to spin in the final cycle.
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
michiganfan9
  • 179 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
if the noise is really loud in the final spin your bearing are starting to go out your washer needs to be rebuilt but it will be cheaper to go buy a new one
Posted on Dec 29, 2008
  • 106 Answers
SOURCE: Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
Posted on Mar 01, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Jul 31, 2009 | GE Washing Machines
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
For spares:
espares.co.uk
Mar 02, 2009 | GE WJSE3110A Top Load Washer
GE washer WSXH208AWW does not spin and drain out.
my GE washer does not spin out all the time on final spin
Sep 08, 2008 | GE WSXH208A Front Load Washer
GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Dec 13, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
52 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
