Question about Makita DPC7321 14" 73cc Power Cutter
HOW IS THE CARBURATOR REMOVED FROM THIS GAS SAW?
  • Makita Master
  • 7,733 Answers
Try some diagrams at -->ERP.
Posted on Oct 13, 2010
How do i remove the carburator
Here is the illustrated parts manual for your saw. it explains how to strip the saw down and everything you need to know. Please click the 'helpful' tab if you find this useful. Thank you
http://www.mediafire.com/download/n25qmj9j7venncu
May 15, 2016 | Husqvarna 445 18" 45.7cc Gas Powered Chain...
Tip
Precautions to take when storing 2 cycle lawn equipment
Any time a weed wacker, chain saw, snowblower, leaf blower, or any 2 cycle machine must be stored for a period of time exceeding 6 months the gasoline must be removed completely from the gas tank and carburator. To do this simply run the engine until it runs out of gas then proceed to choke the carburetor and restart until no start up ocurrs this removes all fuel preventing the carburator from gumming up. This will allow you to store the unit for long periods of time without the worry of having to disassemble the carb. and clean next time it must be used.
on Dec 02, 2009 | Garden
Where are the screws on carburator for my chain saw
Remove the air box and air filter. The 2 screws holding on the carburetor are right on the outside of the carburetor. The screws go through the carburetor through the intake boot and into the cylinder.
Jul 05, 2014 | Husqvarna Forest & Garden No.967012396 345...
Carburator removal partner k 750
Remove the covers and the air filter, the screw heads are Torq 27, with the covers removed, insert a Torq 27 tool through the small hole in the black air filter housing ( close to the back of the cylinder ) and undo the screw that goes into the cylinder, now grab the air filter housing and pull firmly toward the back of the machine, it will come away as an assembly along with the carb, lift up far enough to un clip the throttle rod from the trigger, un hook the fuel hose from the carb, you will now have the assembly away from the machine.
Jun 04, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
Poulan PP446T Pole Saw. Will run only if choke is fully closed. Open the choke and it stalls. Have replaced the fuel filter, cleaned carb, installed carb kit. Cleaned gas lines. Good gas mixture(other saw...
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Jan 22, 2010 | Poulan Garden
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Makita DPC7321 14" 73cc Power Cutter Logo
136 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
