Question about Kitchen Ranges
I have a new kenmore range Model 790.71342700 I am changing over from nat. gas to LP Ihave not connected the stove to a supply yet. The stove is going to a camp in Maine. I have no LP source where I am. I have changed the burner orifices. I have inverted the cap on the regulator. I have turned down the orifice on the broiler. Sorry to be so long winded. My problem is the orifice for the oven. It won't move either way. In or out. Up or down Consequently I have no knowledge of what it is set for. What do you suggest?
gmltwc
SOURCE: sooting of pans in oven
If you adjust the toggle type mini lever to a lower pressure so that the flame is just under licking up through the bottom of the oven and then adjust the air mixture to eliminate all but about an inch of yellow flame it should get rid of the soot.
You want to be sure that the flame is not pulling away from the middle bar where the gas comes out ( a little pull away is ok) and that there is not too much yellow flame. Find the happy medium and you should be good to go.
You may have to adjust the lever and the air mixture a few times before you get it right.
To adjust the air mixture you will need to remove the cover plate at the bottom towards the back, then loosen (no need to remove it) the one phillips head screw holding the air mixture cover in place. adjust the air mixture by moving the cover left or right letting in more air or restricting the flow of air more.
BE CAREFUL, to determine if the mixture is right you will have to turn on the oven bruner and everything will be hot. Wear protective clothing and BE CAREFUL to not burn yourself.
You can find a manual for this model by searching google for "ge xl44 manual". It was the first return when I did the search.
Here is a link http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=ITEMID&itemid=003678171 if they leave it, otherwise you will have to search for it yourself. They explain how to adjust the air mixture in this pdf on pages 35 - 38.
Posted on Nov 26, 2008
SOURCE: Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Posted on Jan 05, 2009
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 8 Answers
SOURCE: 2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Posted on Jan 20, 2009
MNTECH
  • 1543 Answers
SOURCE: natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Posted on Apr 20, 2009
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
How to change over to lp gas on a kenmore model 79074239310
There is an item called a regulator, it is not the one that is just out of the tank. This one you can purchase it is only about 2-3 " in size and you install it where your propane line connects to your stove, at the end of your yellow or some times stainless steel line. Once installed all you do is flip the little cap on top of the regulator to the desired position Nat. or L.P. which means for natural gas use or liquid petroleum (propane). It allows you to use your stove with either one with just the flip of the cap on the regulator. They cost anywhere from $40 to $60. It is fast and easy, you can do it yourself. When you are done make sure you check for leaks before you use it. It is always a good idea to consult with a professional. Hope this helps and good luck.
Dec 25, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
If you can locate the range manual it will have instructions on how to do this.
Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
Best of luck to you!
Apr 11, 2011 | Ovens
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
Where can I find conversion information for going back to nat from lp dynasty or jade residential stove
It is pretty simple either you can purchase conversion kit thru Dynasty (new name Jade) PH # 800-884-5233 or ask them for the proper size of the burner orifices and drill them out, flipper the cap on the gas regulator to Nature gas setting, afterward test the stove and adjust the air/gas mixture. Have fun.
Dec 05, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
