I have a Bradford White Water Heater MITW50L6CX12. The blower is working and the burner was lit for a while but then went out.
SOURCE: bradford white hot water heater
Glenn, thank you for responding to my question on the bradford white hot water heater. It is an electric hot water heater, 7 years old. Our water is good in this area, not considered hard water. We do not have a water softener. Appreciate any advice you can give me.
foyeb
Posted on Jun 30, 2008
  • 3 Answers
SOURCE: water heater burner flame is low
frist did this heater go under water if so call the pros.this can be do to dirty orfic on burner. clog presure regulater at gas meater check other gas applince.
Posted on Sep 17, 2008
larryyb
  • 291 Answers
SOURCE: hot water heater overflow
check the pipes on top for leaks and if non then your water heater is leaking from inside and that cant be repaired / larryyb
Posted on Dec 11, 2008
  • 102 Answers
SOURCE: Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
Posted on May 05, 2010
SOURCE: My bradford white 50 gallon
Usual suspects :: faulty thermostat, or heating element going bad.
More info, let me know.
Charlie
Posted on Jan 12, 2011
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
I have a Bradford White model# MITW50L6CX10, serial# TA4176718-130-131, 48 gal., gas, power vent. The vent is running constantly, and when the burner lights it burns erratically even going all the way out...
1) First suspects include Honeywell icon gas control valve, loose-or-bad wiring, and dirty burner parts.
2) MITW50L6CX10 blower number is 239-39785-00. Blower is working, but communication between blower and gas control valve are suspect.
Water heater has 6 year warranty
Water heater was manufactured January 1999.
http://www.bradfordwhite.com/findaserial.asp
3) Typical service manuals for M-1-TW-50 TTW series show how to test and replace Icon gas control.
Multimeter is required for testing.
Also shows how to clean burner parts and combustion chamber and air intake to catch up on regular maintenance.
http://www.bradfordwhite.com/images/shared/pdfs/manuals/46238-A.pdf
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Fasco Bradford White Hot Water Heater...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
http://www.bradfordwhite.com/supportserv.asp
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
May 03, 2010 | Water Heaters
What causes soot build up in burner chamber
Sounds like you're not getting enough combustion air.
If you have a draft motor or blower make sure it is running.
Apr 30, 2010 | Fasco Bradford White Hot Water Heater...
The blower is running constantly, trys to ignite gas burner,no hot water
the Thermos coupling has gone bad, call the manufacture and talk to customer support.
Apr 26, 2010 | Fasco Bradford White Water Hot Heater...
Hello, thermostate will not stay lit. vacation
Hello, if your going on vacation any way, just shut the power to it off at the breaker box and deal with it later.
Jul 07, 2009 | Fasco Bradford White Hot Water Heater...
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Heating & Cooling Logo
277 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
