Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Error 0xc1ab0003 and 730:lib_micci2_tango.c - HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Posted on Oct 20, 2010
5 Suggested Answers
  • 4 Answers
SOURCE: Error messages on display...
Please review the excerpt from HP technical support website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&lc=en&cc=us&dlc=en&product=441240&rule=31105&lang=en Use the instructions below to resolve the issue by restarting the product. 1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on. 2. Open the cover of the product and remove the print cartridges. 3. Close the cover and wait for the Insert Ink Cartridges message to display. 4. Disconnect the power cord from the back of the product and wait for one minute. 5. Reconnect the power cord. If the product does not automatically turn on, press the Power button. 6. Open the cover and reinsert the print cartridges. 7. Close the cover. If prompted, print a calibration page. 8. Reconnect the USB cable, and try to print a print job from the computer. If these steps did not resolve the issue, contact HP technical support for assistance.
Posted on Jul 27, 2007
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
SOURCE: Error:0xc1ab0003
how can this be fixed
Posted on Apr 20, 2009
  • 105 Answers
SOURCE: I keep getting the following error message:
This is an operating system error. Take a look at Microsoft's Knowledge Base for this error.
Posted on Nov 09, 2009
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Event ID 11
Please perform a erase operation and check if the drive does it, If its not then go ahead and check the SCSI controller if you have a spare one replace it.
Aug 22, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
Aug 17, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
914 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
