Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Both fans are running but compressor will not run
  • 316 Answers
Is the compressor hot or cold to the touch? If it is cold, the problem is very likely going to be your main control motherboard, located behind a panel above the compressor. You can test this board by putting an AC voltmeter from the terminal that the blue plug plugs onto, the lead that has the black wire going to it, put a test lead on that terminal, and the other test lead to the white plug next to the blue one, and clip your test lead to the terminal that has the orange wire going to it. If you have zero volts AC, that board is bad, if you do have 120 volts, check that the compressor is still not running. Sometimes in testing, the compressor will kick on, so listen for a new refrigerator humming sound as you are testing.
Posted on Oct 13, 2010
Samsung RF2178CBPX99. When do internal cooling fans cycle? Frenchdoor model. We have just reinstalled this unit. We dont hear internal or condensor fans running
When the compressor is running at least the freezer fan should be on and if not also the evaporator fan in the fresh food section should be running when it calls for cold air but basically anytime the compressor runs the fans should be running all of .them. a lot of times when there's a problem with the start relay and run capacitor on the compressor d external and internal fans will not come on what you need to do is find out if the compressor is getting hot and not running
Appliance 911 Sea Breeze
Oct 01, 2015 | Samsung Refrigerators
Fan not spinning
If the fan on the backside is not spinning it could be a bad fan-motor. When the fan runs the compressor should run as well. If the compressor is not running the fan should not be running either, so you should unplug it for about an hour, then plug it back in and see if the compressor unit starts up. If it doesn't, it is probably something wrong in the control circuit for the compressor. It could be the thermostat (check that it is set correctly). If the compressor starts up but the fan does not run, it is most likely a bad fan motor or bad wire leading to the fan motor.
Jan 20, 2014 | Cuisinart CWC1600 Wine Cooler
Inside fan never shuts off. Freezes fine.
The fan is controlled by the by the electronic control located in the back by the compressor.
If the fan is running all the time there is something we need to determine before replacing parts.
Is the compressor also running all the time? The inside fan should run at the same time as the compressor, if they are both running then check and clean the coils behind the freezer. If they are clean and both running then check the door seal to make sure it is not broken or torn. If all these are okay then the compressor is just wearing out and getting inefficient.
If the compressor is not running and the inside fan is running the problem is within the control board down by the compressor, this is a replace only component and runs about $180.00
Apr 22, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
We have a Kenmore 596.50399001 side by side refrigerator. The center divider can get very hot, the refrigerator compressor is running but not the fan. If the refrigerator is moved or shook the fan will...
If you are talking about the freezer fan motor, it should be running if the compressor is running.
if the compressor runs without the fan running the compressor will overheat and become damaged.
The mullion heater in the door divider is not affected by the compressor.
Mar 13, 2009 | Kenmore Refrigerators
Fan running but compressor is not
which fan is running? evaporator fan or condenser fan?
if the condenser fan is running and the compressor is not, try to feel the compressor if it is VERY hot,
( use caution please)
if it is very hot, unplug the unit, put some wet rags on top of the compressor and let it cool for a while.
after 4 hours, try it again, plug it back and observe the compressor if it would run,
let me know what happen,
tnx 4 using fixya,
drcool
Sep 26, 2008 | Whirlpool Refrigerators
Compressor fan
This sounds like it is caused by either a high pressure reset. Or the compressor is tripping a high temperature limit internally. One thing you may be able to do is to hose off the coil surface with a garden hose on the outside (condensing unit) this would allow the operating pressure to drop if it is dirty.
Hope this helps Ya
Jul 06, 2008 | Goodman CLJ36AR42 Air Conditioner
Condenser fan inop
genarrly the fan motor runs in conjunction with the compressor assy, ifhte compressors not runnig you wont get hte fan to run either. is the compressor running??? if so check the wiring between the 2 components
Mar 23, 2008 | Refrigerators
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
