Question about Makita G6100R 5800 Watt Generator
What is the recommended spark plug for the Makita G6100R generator
    President:
  • 2,777 Answers
The recommended spark plug is an NGK B6ES plug, you can buy it for just $4.18 with free shipping and not tax from the link I will provide at the bottom of my answer here. This is definitely the best plug for this generator, and is recommended by the manufacturer as well...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
http://www.amazon.com/gp/product/B000CJ3X4O?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000CJ3X4O
Posted on Oct 13, 2010
120/240 switch on makita G6100R wire loose need picture of full power switch
There is a manual uploaded .pdf with on page 33 a wiring diagram .
http://www.fixya.com/search.aspx?ref=ser&s=makita%20manual%20g6100&
Jun 16, 2017 | Makita Saws
Generator starts with 1 pull and runs 5 seconds then shuts off. Carb is clean inside.
Must be something wrong with the governor or the links near the carb. Check the springs and linkages. These are usually at fault. If thereafter you still don't find something, must be the jets on the carb. One of it maybe a little dirty.
Jul 07, 2014 | Makita G6100R 5800 Watt Generator
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
Low output about 60 vac.
On the bottom right side of the engine there's a throttle with a set screw. This set screw is a fine adjustment for voltage control. The lever should be pushed until the set screw makes contact with the stop plate. Using a voltage meter, adjust the set screw until you hit 110 volt and then lock the set screw. I just bought the same generator, it was putting out 85 volts. Witha phillips screwdriver a wrench and a multi meter, I had 110 volts in less than 2 minutes. It now operates flawlessly.
Jul 14, 2011 | Makita G6100R 5800 Watt Generator
I have a G5500R Makita Generator, It has been stored for sometime. I filled it with gas and discovered a leak coming from the left side of the Carb. it appears that there is either a missing screw or...
hi there
pauly46 here
sounds like you will need to remove carby and give a good clean and soak for a while
to remove to green gum / varnish causes blockage of passageways and fuel needle valves to stick and remain open / or closed as well as making it run funny if it runs and flood as you mention
note do not soak any longer than 20 to 30 mins in a carb type cleaner solution as these can attack
non metallic parts and runin them , use compressed air to clean passageways and jets
blow some brake cleaner through them to , if the unit still floods after this , replace the fuel needle valve and seat
here is web site for parts list and parts ordering on line
http://www.ereplacementparts.com/makita-g6100r-generator-parts-c-97_683_688.html
its a god site take look
hope this helps
cheers pauly46
May 11, 2011 | Makita G6100R 5800 Watt Generator
Auto idle does not work propertly on makita g 6101 generator
The battery charging is also a load. If the battery is not well charged or old it may need about 60 - 120 W to charge, which is not "Idle".
Jun 24, 2010 | Makita G6100R 5800 Watt Generator
Will not start
Do you have spark to the plug, do you have the fuel valve shut off? have you cleaned the air filter? is the govenor free? is the spark plug clean? if so make another post and I will give you some more points.
Jun 19, 2009 | Makita 9 Hp 4,300 Watt Portable Generator...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator no power
Hi Laurence,
Hope you had as good a holiday as I did :-)
Yes the squareish thing in there is a kind of voltage regulator. More correctly, your brushless generator is using this capacitor to regulate output voltage by means of a resonant circuit between a winding on the stator and this part. The short answer is that you more than likely need a new one and because of its particular shape the only realistic source of the new one is Makita.
I disagree with the service tech about the testability of the thing, my Fluke 112 DMM has a capacitance function that would let me tell if your capacitor was shorted ( 0 mfd reading), open (infinate mfd reading), or some value that could be compared to whatever "known" one was applicable. In this case I'd take a loose guess that the reading of a good one is something like 20 - 100 mfd, but that's just a guess.
let me know if the new capacitor doesn't get it,
Carl
Dec 31, 2008 | Coleman Powermate Powermate 5000W...
Makita G6100R 5800 Watt Generator Logo
121 people viewed this question
Top Makita Electrical Supplies Experts
obsteiner
Tom Chichester
Ogbonna promise
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
