Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Frigidaire stackable will not stop filling with water or agitate.
I have a Frigidaire stackable that will not stop filling with water or agitate.
It will spin and siphon. The water valve works ok during the rinse/spin cycles. I just purchased this used item for my son's apartment. I did lay it on its back in the bed of my truck. This item was a nightmare to get into the small opening in his apartment. I actually had climb over the machine to get out from behind it after plugging in the cord. I purchase additional hoses and joined them to the originals, guess I should have tried to get a longer cord also. The combo was working fine before I layed it down in the truck, got a hernia getting up to the second floor, tore up the kitchen floor, had to remove the pantry door and kick/shove pretty hard to get it turned into its hole. I did not realized the problem intil it had been shoved into place and I could not find any model/serial number from the front. It is probably 4-6 years old.
Is there a general location for the reset button on Frigidaires??
I did try to "unstack" the dryer. Thought it would make the installation a littel eaiser. I did removed a clear plasctic tube 5/16 - 3/8 from the front behind the wahsher controls, and tried to unplug the wiring but got a little frustrated, put it back together and went to Home Depot to get the additional water hoses. Is the clear hose the vacuum for the tub fill process? Maybe I pulled it off from the tub end? If so, would that coincide with the agatation issue?
Thanks, Doug
  • jbug99 Jun 02, 2008
    I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing machine works fine on the regular cycle but, I have had this problem with this cycle also. For the regular cycle, this problem is fixed by re-cycling the regular cycle by advancing the cycle to rinse and allowing it to finish. This does not work for the delicate or permanent press cycles. This problem is avoid if the regular cycle is never interrupted. However, this does not work for the other two cycles. Is there a fix, what is the problem.
  • johnsdw Jun 02, 2008
    Washer is running over. I will check the hose to the water level switch. Could this also be the reason the washer will not agitate? Thanks , Doug
    Genius:
  • 1,028 Answers
Is washer running over or just never filling? if running over suspect small hose to water level switch kinked off or a hole in it..if never filling suspect drain hose too low or no air gap between drain hose and stand pipe hose must catch air to break siphon
Posted on Jun 02, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/Dryer flse60rgs1 Starts filling but won't stop no matter what setting its put on it just fills the tub, and ultimately overflows
The problem is most likely the float switch or it could be a stuck fill valve. If it is the fill valve, it will stop filling if you unplug the machine.
You can find the parts and diagrams at partselect.com
If you need more help, post a comment.
Thanks,
Tim
May 14, 2009 | Kenmore 22642 Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal De
