Question about Microwave Ovens
Simpsons donut maker - Microwave Ovens
How to replace fuse Samsumg microwave me179kfetsr/ac
This is a goody---you have to take the cabinet off then over by the control board you'll see a small circuit board with a donut coil magnet---on that is normally the fuse but it maybe on other circuit board----DO NOT MESS WITH THE MAGNATRON--DO NOT LEAVE IT PLUGGED IN WHILE WORKING ON IT---GL
Sep 19, 2017 | Microwave Ovens
How do I remove case of GE Jem31 microwave. There are only 3 screws on bottom and the back screws at the bottom are star shaped with donut around a peg.
You need a special screwdriver to get those star shaped screws out. I would suggest going to a hardware store or their website and look for "Tamper-proof Torx" screwdrivers or bits. You are probable going to need either a #15 or a #20 bit to get those screws out. Normally there are no screws on the bottom that hold the side cover on unless they are actually on the side of the microwave. The front is held on by clips mounted on the cover itself, so you need to make sure you catch them when you put the cover back on. Good Luck!
Apr 30, 2014 | GE JEM31 Microwave Oven
I can't find my booklet that came with my mini donut maker and need the basic donut recipe.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, if available, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 26, 2011 | Microwave Ovens
Instructions for a russell hobs temptations donut maker .
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
I hope this helps.
Jan 01, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
How to program my Hamilton beach Coffee Maker,49464 To make coffee in the am before I get up.
12 Cup Programmable Coffee Maker 49464 could help you to operate your Hamilton Beach Coffee Maker. Anyway, if you are looking for a best coffee maker that can extract a perfect cup of coffee, allbestcoffeemakers.com is a great choice. Hope it helps you!
Nov 30, 2010 | Hamilton Beach Microwave Ovens
The ice maker has stopped working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 14, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
