Question about Gateway 3200XL PC Desktop
I have a 3200lx that was in the box out by the street. I got home and notice there was no ram or hard drive. I plug it in and pushed the power button. nothing happened. I bought the ram and then tried again, still it does not turn on. can you help me.
    Scholar:
  • 50 Answers
Well, there is probably a reason that it was on the street. Was it sealed, probably not?... so, you brought RAM...well, most PC's will power on and Beep to tell you there is an Issue with the RAM. This sounds like there is a Motherboard or Power Supply issue. No point in investing in a Harddrive. Just put it back where u found it and return the RAM asap. Or get someone a Techie to test the Power Supply and the Mother board!
Posted on Oct 13, 2010
Caps lock flashes 45 times and shuts down
I would remove the power adapter, battery, hard drive and RAM. Plug the power adapter in and press power on. If it is still dead, suspect the GPU. If it goes to bios screen, remove the power, fit the RAM and plug the power adapter back in.Press power on . Repeat with hard drive and RAM if RAM on its own worked. You should be able to deduce the problem from there.
Jan 10, 2014 | Dell Latitude D630 Notebook
Toshiba Satellite Notebook M45-S351 I recently purchased an upgraded hard drive - 160 GB Samsung Spinpoint and upgraded the RAM (Crucial 1 GB, bringing the total to 1.5 GB of the allowable 2 GB). Impetus...
Remove thwe new RAM and hard drive. Does it boot to the BIOS menu? If yes, add the hard drive and do the same again then add RAM and do the same.
I suspect something does not fit in properly. Probably the RAM.
Don't forget to initialise the hard drive if trying to format it. The System disk should take care of that.
Dec 21, 2010 | Toshiba Satellite M45-S351 Notebook
I was removing the video card to tighten a nut. I unplugged the power cord and pushed in the power button to drain excess power, notice the solid green light went to flashing. I then removed video card to...
Open it up again. Take the video card out. Take the Ram out. Unplug the hard drive. Unplug the other drives. Unplug the network card(s). And unplug anything else that is tied to the motherboard. Now plug it all back in snugly.Finally,turn it on. It should be fixed.
Nov 23, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
Took RAM out. Put RAM back in. Removed hard drive. Reconnected hard drive. Connected a second hard drive as a slave. When I plugged it back in I noticed a small red LED (PLED) beside the 5th card slot had...
Single long beep - the RAM is no longer recognized as present. Try the ram stick in another pc, if it works there then the motherboard has died, you will have to replace it.
Oct 20, 2010 | DFI CA64-EN Motherboard
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
Computer will not start. screen has blue vertical bands
Dear there are three possibilities
1- Ram Problem
2- Ram Slot Problem
3- Hard Disk Power Plug
So change your ram or slot if problem will presist then you should change your Power Plug cable. Fix your power plug of your hard disk properly.
Good Luck
Aug 21, 2009 | Dell 16X Internal DVD-ROM Drive for...
My power stering fluid is leaking bad
sounds like the seal in you cap is bad
Jun 02, 2009 | 1999 Toyota Camry
Power Adapter for Bytecc 3.5" EXTERNAL SUB-SYSTEM
These are readily available on the net. Do a Google search for:
pa-215 "switching adapter". (Enclose the words in quotes, as shown.) Also, check eBay, which probably has them at good prices.
Jun 25, 2008 | Computers & Internet
INSTALL A 2 MB RAM FOR MEDIAN PC MODEL 8030..
Most RAM today, is plug and play, would you know the specs of your motherboard?
Installing RAM, is something you should get someone at least semi experienced with Hardware to do, if you are then open your case, and you will notice 3/4 slots, one or more of these slots will be filled with RAM already, Providing you have enough empty slots for your new RAM, you can leave the existing ram installed or remove it - your call.
There are many helpful images here
It is basically inserting the RAM, the correct way around and clip it in. In the case of Installing another hard-drive or replacing your old HD, you will have several cables, The main ones are the power, and data pathing cable. Illustration here
Be careful not to disrupt any other devices/cables inside the machine and it should be good to go.
Mar 27, 2008 | Computers & Internet
Gateway 3200XL PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
