Question about Ovens
How do i replace the inner window on the oven door
  • Ovens Master
  • 6,993 Answers
Disconnect the oven's power cord from the electrical wall outlet. Although you will not be working directly on electrical components, it is good safe practice to disconnect the power source from appliances before making any repairs.
Open the oven door halfway. Place a large nail or screw into the empty hole on the side hinge along the side of the door. A hinge is on each side of the door. The nail will keep the hinge from closing into the oven after you remove the door. Close the door as far as the nails will allow.
Grab the sides of the oven door with your hands and pull the door straight up until the door stops. Push the top of the door toward the floor and pull the door toward you to release the door from the hinges. Lay a sheet on the floor and place the door on the sheet with the handle side facing the floor.
Remove the screws that secure the inner liner to the outer door with a Phillips-head screwdriver. Some models only have two screws at the top edge of the liner. Other models will have up to six screws on the panel and two on each side of the door. Lift the inner panel up and slide the inner panel away from the outer panel.
Use the Phillips-head screwdriver to remove the two inner screws that secure the door handle to the oven door. Lift up the oven door and pull the handle and the top trim behind the handle away from the door.
Remove the three screws on the bottom edge of the door that secure the bottom trim to the oven door with the Phillips-head screwdriver. Pull the bottom trim off of the door. Locate the two screws that secure the right side hinge assembly. The hinge assembly is the part on the inside of the oven door that the hinge slides into. The screws are on the bottom edge of the door directly under the hinge assembly. Remove the screws with a Phillips-head screwdriver and pull the hinge assembly out of the door.
Fold the door insulation back and pull the broken oven door glass and frame out of the door. Put leather gloves on your hands and pull the broken glass out of the metal frame. Place the replacement glass into the frame and set the glass and frame back into the oven door. Position the door insulation back over the edges of the metal frame.
Slide the hinge assembly back into position and secure the hinge assembly to the oven door using the two retaining screws. Reattach the bottom trim and secure the trim to the oven door with the retaining screws.
Lift the top of the oven door up slightly and line the upper trim and door handle into position. Secure the upper trim and door handle by attaching the retaining screws from the inside of the door. Tighten the screws with a Phillips-head screwdriver but do not over-tighten.
Slide the inner panel back over the oven door and secure the inner panel to the door with the retaining screws. Pick the oven door up by grabbing the door at the sides with both hands.
Place the bottom edge of the oven door over the two side hinges on the oven. Line the oven door slots over the hinge pins and push the door down until the hinge pins lock into the oven door. Open the door slightly and pull the nails out of the hinges.
Close the oven door and plug the power cord to the oven back into the electrical wall outlet.
I hope this helps.
Good luck.
Posted on Oct 13, 2010
4 Suggested Answers
  • 833 Answers
SOURCE: how to replace inner oven door
Generally, the job is just alot of screws. Depending on the model, most screws are found either inside the door or on the lower edge. Some models...mostly GEs... have a way of removing the door from the hinge. Doors are heavy and are usually spring counterweighted.
Is it an easy job? Depends...if you're mechanically inclined it is straight forward. You will need an assistant as these doors do come apart and they are heavy. Often, the manufacturer or a parts house has an exploded diagram to let you see what you're facing.
Oh, and use a good quality screw driver and apply pressure when turning out screws. You don't want to ruin the heads!
Posted on May 27, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Ariston oven window pane out
Take a look at http://ovendoorglue.co.uk/fix-oven-door-glass/ whish should help explain how to remove the oven door, take off the fascia and glue the inner glass.
Oct 28, 2012 | Ovens
Kuppersbusch microwave door glass replacement
Did you resolve your problem as my inner door just shattered and will need replacing? Do you know why yours broke?
Jan 09, 2012 | Ovens
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
Is it necessary to repace the entire inner door
You should be able to just replace the inner door glass. They are usually available as a seperate spare part.
Go to the manufactures web site, and if neccessery send an e-mail to them.
Feb 16, 2010 | Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
152 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
