Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Replaced a battery turn switch on try to move wheelchair forward all i hear is a click and it doesent move .
  • 692 Answers
Not a lot of information to go by but the click you hear is the brake releasing but you are not getting anything to the motor. Usually with Pride it is the freewheel lever or levers are in the freewheel rather than drive. Check to make sure levers are in the drive position. If they are in drive then the joystick lights should be flashing an error code. Also make sure that the charger is not plugged in. Thats not much help but I went by the info you gave Hope this helps
Posted on Oct 13, 2010
Hoveround MPV4
Check your battery connections, make absolutely sure it is connected correctly.
Place a multimeter in the XLR plug (joystick). You should have around 26V reading if batteries are connected correctly.
Check the free wheel levers. place the chair in free wheel and move back and forth a couple of times. Place the chair back into drive, turn on controller and try to drive. ( This is not typically associated with a clicking sound but will ensure your brakes are not on)
If you are still hearing a clicking sound, it could be a problem with the brake or a motor. A qualified technician should really look at it for you.
Apr 19, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
What's your problem?lock or unlock
try holding the on off button till you hear a beep. then push the joystick forward and hold till beep then pull back till you hear a beep. you should be locked, then repeat to unlock.
Jul 07, 2012 | Invacare Supply Group Invacare Pronto M91...
Chair won't move. Power seems okay. Clicking in rear when joy stick is pushed forward.
check the freewheel levers. the clicking you hear is the electric brakes energizing. hope this helps
May 27, 2011 | Pride Health & Beauty
I bought used mprv 4 hooveround, been setting for a couple years and I put new battries in it,I put it in driveand all the lights come on you can near something running when you move the lever forward,...
take the freewheel levers and move them up and down a few times then leave them both in the up position. Turn on the chair and see if it works correctly The noise you hear are the motors or motor running because one or both levers are in freewheel.The clicking you hear is the electric brakes engaging when you move the joystick Hope this helps
May 06, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Hi, Just replaced two batteries. Chair powers on but I just hear a click sound when I push the button to move chair. please help. thanks.
The fact that you just replaced the batteries indicates a battery problem that has been solved. Please make sure the new batteries are fully charged. The fact that the power wheelchair powers on is an indicator that the VSI controller (joystick) is working. When you move the joystick forward you will hear a click sound from the motors and electromagnetic brakes. The click is the brake being released by the electromagnetic solenoid. If you have a flash code on the controller and the chair does not move you can look up the flash code using the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This motor/brake problem is typical for the Aspire and can usually be traced to the large connector at the back of the power chair. Pull out to disconnect the 8 pin connector and disconnect the 3 pin molex plug. Inspect and clean with electronic contact cleaner the silver pins until they are shiny. Spray clean the plugs. Work the plug in and out to clean the inner contacts. If the chair now runs you have traced the problem to the main harness receptacle and the VSI controller plug. The only cost effective repair of the the main harness receptacle is to replace it. The VSI plug is can be cleaned several times before it needs to replaced or the controller rebuilt.
If you need to replace a motor/brake assembly you need to contact a qualified technician who can troubleshoot further with a PP1 programmer to read the fault code history log. The technician will also have a digital voltmeter to verify your motor/brake problem. In my experience, the motor/brakes can last up to 3 years depending on use. The wiring harnesses at the rear location are easily hit and are usually more problematic because of their location, collecting dirt, moisture, and corrosion. Hope this helps,
Nov 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
It will move side to side But it has no forward and reverse and the batteries are brand new
contario With little information other than what you are telling me your problem seems to be the joystick. If the chair's joystick will make the motors turn your chair but won't go forward or back then the problem is in the joystick and will have to replaced. Sorry hope this helps
Oct 26, 2010 | Home Health Pacesaver Boss 6 Series Heavy...
I just purchased a used Jet 3 ultra power wheelchair...after charging it up I turn it on and the red light is flashing and it makes like a clicking sound when i try to make it go forward..cand you please...
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Oct 22, 2010 | Jet 3 Ultra Power Chair
Batterys charged. I turn switch on. all the lights come on. Joy stick doesn't do anything. Pronto m91 (trulffes@asisna.com)
truffles e-mail me at lennieg2000@yahoo.com. I need to know if you are getting any flashing lights on your joystick and are you hearing the brakes click when you move the joystick. Thanks
Oct 18, 2010 | Invacare Supply Group Invacare Pronto M91...
Bought brand new batteries. have power, but chair will not move. Chair been out of use for approx 5 years.
Zim When you turn the power on and all the lights on the battery level are lit and you move the joystick forward Do you hear a clicking sound coming from the motors? You are not getting any flashes on the lights? If you don't hear the electric brakes energize or click when you move the joystick then they are probably stuck to the motor housing. Try putting the chair in freewheel and trying to push it like a manual chair. It should roll freely. If it doesn't then the brakes are stuck and you won't get any sort of error code. I don't know what brand of chair you have so I can't tell you what steps to take to free up the brakes. Try rocking the chair back and forth to freeup the brake pads when you have it in freewheel If you are mechanically inclined you can take the brakes off the back of the motors and try to unstick the pads but be careful not to break the wiring from the motor harness to the brakes. Let me know if this helps
Sep 11, 2010 | Health & Beauty
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
53 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
