Question about AT&T E2717B Twin Cordless Phone
My AT&T E2717B cordless phone can't connect - how can I get it to work again?
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Nov 14, 2013 | Motorola Mobility L512bt Cordless Phone
Deleted handset by mistake how do I re register it. your problem?
You can try removing the battery from the deleted phone. Then put the phone into the main charging unit, the one with the answering machine, for a little bit. Reinstall the battery and put in the main unit again. Let it charge a few hours and try it again. Hopefully it will renegotiate it's status and be recognized by the master again.
Aug 29, 2012 | AT&T E2717B 2.4 GHz Twin Cordless Phone
How do I fix the speakerphone on a Uniden dect 6.0
check headphone socket, clean & some heating. or" find switch connection & that have short pin & open it.
May 29, 2012 | Uniden DECT 6.0 Cordless Phone ID
Need a manual for AT&T cordless phone model E2717B
I'm sorry for the difficulties you're experiencing in getting the Manual of the Cordless Phone. Please click here to download the same.
Please let me know if you require any additional help.
Thanks for using FixYa.
Sep 26, 2011 | Lands Phones
Had a bad electrical storm. The next day my cordless AT & T phones ( 1 base with answering machine and 1 remote phone) had no dial tone. They both ring on incoming calls but unable to connect. They...
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
Apr 29, 2011 | AT&T 650530003417 Cordless Phone
Can not get a dial tone
maybe someting to do with freqencies
Feb 23, 2018 | AT&T E2717B Twin Cordless Phone
I don't know how to reteive messages - no instruction booklet
My bt phone is a bit like that. have you got a menu button? If not try pressing the first button down on the left of the screen. It shld change to msg in the screen to answer msgs. G luck.
Apr 26, 2009 | AT&T E2717B Twin Cordless Phone
Kxtg2344 panasonic cordless
May be the problem with the handset antenna. Check the antena connection.
Apr 09, 2008 | Panasonic KXTG2344 Cordless Phone
GE 5.8 ghz cordless phone
Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
Nov 05, 2007 | Uniden Cordless Phone
Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Oct 09, 2006 | Sony SPP-S2730 Cordless Phone
AT&T E2717B Twin Cordless Phone Logo
128 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
