Question about JVC Car Audio & Video
I have a jvc head unit i've used in a couple cars now i just put it in my fiat brava and although it can remember the radio stations i program when i turn the car off it forgets everything else (like the time background colour cd track user eq settings everything but the stations) is there a second perm. live i need to find?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
Are you sure the yellow wire is going to a constant source??????
Posted on Oct 14, 2010
  • 1 more comment
  • poffie2006 Oct 14, 2010
    i cant remember if its the yellow or red thats live ill make sure. are they both constant live when it was in my golf it had 2 constants and a key? its just strange that it can remember my radio stations but not my presets
    think my yellow is my key as when i make it constant stays on all the time instead of when i turn the key like before
  • kenw392
    kenw392 Oct 15, 2010
    yellow is constant and red is switched. the yellow wire controls the memory.
Put new battery in my fiat brava but it still goes flat after a couple of days
it takes your battery to start your vehicle, once started the electrical power is genereated by your alternator, if your altnernator is bad or going bad the car then relies on the battery for the electrical power, the battery will go down or dead because it cannot sustain a charge.
it sounds like you need to test your alternator and maybe replace it.
Aug 11, 2010 | Fiat 124 Cars & Trucks
Hi i have a fiat brava car and need to unlock the radio, i have the code,
Quote the radio MAKE + MODEL and find the instructions on this free website
http://www.radio-code.co.uk/code-entry-help.php
Jul 19, 2010 | Car Audio & Video
How you put fiat brava radio code in
It depends on the MAKE + MODEL of your radio.
A collection of free Code Entry Instructions can be found here
Mar 14, 2010 | Car Audio & Video
The light on the radio of my fiat brava stays on even when the radio is turned off and it drains the battery. Can you help me? Thank You
someone put the memory and "switched " wire in the same power source , usually yellows "constant" and reds "switched" see in there if those wires are tgether coming from the radio, if so, seperate them then use a 12 volt test light to fuse box while turning cars key on and off till u get a flashing action from the test light .... thats youre switched source
Nov 12, 2009 | Car Audio & Video
Manual for a car radio
Your best bet would be to look on JVC.com I bought a JVC head unit from a friend, and i printed out a manual on the jvc website, and it was free
Nov 19, 2008 | JVC Car Audio & Video
Fiat brava 2000w
If the head gasket is starting to go, the the water gets vapourized inside the engine. The water level will go down, sometimes you get white smoke from the exhaust, the car consumes more fuel and has less compression and performances.
If you are lucky, and you check the water you can drive a car with bad head gasket for many miles, before it blows completely and leave you on the middle of a motorway.
If the head gasket is starting to go better to fix it or to replace the car.
The part costs only thirty pounds or so here in UK, but the job is expensive, as you need to take apart the head.
Here in UK you dont pay less than four hundreds pounds, probably a bit more, depending on the garage.
Oct 26, 2008 | 2007 Fiat Pininfarina
Timing belt problem on fiat brava
i recomend you to buy a book with the timing marks because i had the same problem and i have one of the best repair information software online and that could not even help me
this type of car has to many marks and you need to make sure where they go, but if the timing belt still complete and in the car all what you have to do is mark it with liquid paper or some kind of ink and put it back the same way
May 29, 2008 | 2006 Fiat 124
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
91 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
