Question about Whirlpool Refrigerators
Thanks for being there. I bought a Whirpool refrid/ freezer on top from a friend and the water pump behind ans at the back of the unit was broken. I had a repair man replace the water pump. What happens is the try overfills. The water won't stop flowing. Do you think the pump is the wrong kind or is there a shut off switch at the ice tray unit? Thanks Randy Banks
  • 316 Answers
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Posted on Oct 13, 2010
Hello,have a whirlpool gs6nbexrb01,side by side.how do I remove the dispenser touch panel unit in freezer door, thanks
Heat from the night light probably has cracked the delivery tube for the water dispenser. There are repair kits available. from Whirpool. Instructions are included
Sep 29, 2016 | Whirlpool Refrigerators
Eaton's Viking Model 1266F fridge leaking defrost water
Your idea/plan sounds pretty good. There is a drip pan under the fridge right? it might be a good idea to run it into that. Good luck!
Jul 26, 2014 | Viking Refrigerators
Water forms in front and side of fridge. water pan has some water in it. freezer on top refride bottom. no ice maker.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 23, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Leo Ponder
imufo2
Aug 23, 2011 | KitchenAid KBLS20EVMS
Good Morning. I own a Whirlpool Roper Refrigerator / Serial ER5025124. there is water dripping from the top of my unit into the bottom of the unit and it stands. I used a wire hanger thinking the...
Leo Ponder
imufo2
Aug 17, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Water dripping from Funny looking . unit in ceiling of refer
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 09, 2011 | Frigidaire FRT15B3A Top Freezer...
Water keeps developing on the floor below the freezer door. The seals are ok and the freezer compartment it's self is fine and doesn't appear to be leaking from there. Any advice would be appreciated....
You have a blocked drain.
There is a condensation drain at the back above the pump with a small tube that is meant to deposit water onto the pump for evaporation - the drain gets blocked so the condensation flows out through the front door. Also makes big rivers of ice at the back of your freezer behind the bottom shelf??
Solution - Dismantle the inside of the freezer - take all the plastic trim outof the back of the freezer with a screw driver - don't worry, it's only trim and goes back easily. Eventually you will see the drain collector (flat V shape) and at the point of the V is a small hole, pour warm water in this till it drains to the pump at the back, instead of down onto your floor at the front. You may need to clean the hole too as it gets gunked up.
You can also help by finding the drain tube above the pump at the back and gently inserting a chopstick or similar untill the warm water empties onto your hand !
Takes about an hour all in all and has been fixed for a year now on mine.
Mar 30, 2011 | Hotpoint FFM90 Bottom Freezer Refrigerator
Water in the refrigerator, leaking down back, collecting under bins. Can't find a drain hole either in the freezer or the refrid. Can't find a channel in the freezer that may be clogged. Have turned off...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 12, 2009 | Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water in the bottom of the refrig
HI thanks for your question. the drain tube is clogged. to repair turn fridge off, for at least 24 hrs. as the frain tube is between the inside and outside wall. so its just not dirt in the drain tube, its frozen . to clear after 24 hrs . purchase a small plastic tube , go to the drain tray at the back shove the small hose up the drain hose and blow air up the tube . it will unclog. thanks the appliance doc. please rate my answer. thanks.
Sep 22, 2007 | Amana ATB2135HR Top Freezer Refrigerator
Refrigerators Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
