Question about GE Nautilus 24" Built-in Dishwasher
Natutilus..does not drain all the way, should drain hose be higher than the drain
    President:
  • 1,430 Answers
Yes you need what is called a high loop or air gap. Here is a link that should help http://mediasuite.multicastmedia.com/player.php?v=z3q491n5
Posted on Oct 13, 2010
E3 water drainng error
Some drain problems come from the washer drain hose not being high enough to allow for the water to fill in the dishwasher. Make sure the hose is held as high as the washer top as possible before it drains into the sink drain pipe. A good example is your cloths wash machine the drain hose comes from the bottom of the machine then it goes up to the drain that is higher than the basket. This keeps the water level high enough to wash clothes. The dishwasher works the same way. The drain hose must be slightly higher or as high as the needed level in the machine to work. In most cases as high as the dishwasher top or close to it. Simple raise the drain hose.
Jan 20, 2014 | Samsung DMB28AFS Dishwasher
I just install brand new dishwasher, and test it, but it doesn't drain all the water out, can you help.
Hello.
WHen installing your machine it should have a high loop in the drain hose that means the drain hose under the sink is higher at one point that the drain its attached too with a corregated hose this is very easy to usea plastic zip tie and attatch a part of the hose to a higher point than where it connects to the drain. DID YOU DO THAT ?? if not that very likely is your trouble
Hope this helps
Gene
Aug 01, 2011 | Frigidaire 24 in. PLD2850 Built-in...
My washer w6221 won't drain
Check this following things then your washer will be fine.
* Has the drain hose been put flat on the floor?
* Is the drain hose clogged with lint?
* Is the drain hose kinked?
* Is any part of the drain hose higher than 20 cms from the floor level?
* Is the extension drain hose longer than 3 m?
* Is a narrow drain hose being used?
Thanks for your question.
Jun 26, 2011 | Asko W6221 Front Load Washer
Water does not drain in any cycle
I will give you some of the check list.If you check this properly means you are problem will be solved.
*Has the drain hose been put flat on the floor?
*Is the drain hose clogged with lint?
*Is the drain hose kinked?
*Is any part of the drain hose higher than 20 cms from the floor level?
*Is The extension drain hose longer than 3 m
*Is a narrow drain hose being used?
Jun 20, 2011 | Kenmore Washing Machines
My washer drains while its filling
Raise your drain hose up to a higher level. The gravity is letting the water run out because the hose is too low. Drain hose must be at least 30 inches above the floor but no higher than 5 feet.
Apr 04, 2011 | Kenmore Washing Machines
As my washer is filling with water it drains out the drain hose I have a roper seriel cso359605/modelras7133pqo
The drain hose MUST be routed HIGHER than the top of the machine. There is no drain valve, but rather PHYSICS that keeps the water in the machine. Route the hose loop higher than the console, or top of the machine, which ever is higher. Then there wants to be a VACUUM break, so do not seal the hose to a drain pipe. Air need to be able to pass the hose, and go into the pipe. Obviously there needs to be a p trap somewhere downstream of this connection...
Dec 10, 2010 | Washing Machines
Can drain hose rise higher than tub...is length importand or can I cut it?
It can rise a little above the tub but not below. maybe 2 or 3 foot. maybe higher you could try it . It just won't drain if it is too high. If it is below the top of the tub it could drain while filling. Hope this helps.
Dec 05, 2010 | Washing Machines
My whirlpool won't fill up all the way. It just keeps pouring water and draining.
The drain hose MUST be routed higher than the console, or it will continue to drain. There must be a vacuum break (not tightly sealed will work) at the intersection between the hose and the drain pipe.
There is actually no drain valve that keeps the water in, but rather the physics of routing the drain hose HIGHER than the console of the machine. At minimum higher than the machine's top deck.
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The water comes in and drains out without stopping help!
what is brand of this unit? have u got drain hose higher than top of machine? water could b draining out with gravity. try lifting drain hose higher. please reply 4 more help
Mar 07, 2010 | Fisher and Paykel Washing Machines
Washer less than a year old. Top loading. Will
Have you moved recently, or moved the washer for any reason?
Two things can usually cause that.
First, Some part of the drain hose must always be higher than the highest possible water level in the machine. Remember that water flows downhill. If all the hose is lower then the highest possible water level the machine can never fill since water will drain out hose. So, raise the hose higher than the flat top of the washer and try again.
2A, Inserting the drain hose too far into the house drain. or 2B, sealing out ALL air in the drain line by using a hose too tight in the drain pipe or taping the drain pipe tightly with the drain hose in it can both create a vacuum in the drain line which will actually **** out all the water in the tub. This can be tested by pulling the drain all the way out and aiming it into the tub as you try it. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
GE Nautilus 24" Built-in Dishwasher Logo
179 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
