Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
DISCO DURO PORTATIL STOREJET DE 320 GB 286236 1202 NO ES RECONOCIDO POR MI PC DICE QUE LA UNIDAD DE USB NO PUEDE SER RECONOCIDA YA VERIFIQUE EL CONTROLADOR PERO ME INFORMA EL SISTEMA QUE EL INSTALADO ES EL MAS CONVENIENTE, QUE PUEDO HACER PARA RESOLVER ESTE PROBLEMA, NO QUISIERA FORMATEAR MI UNIDAD ANTES DE RECUPERAR MI INFORMACION, POR SU APOYO AGRADESCO DE ANTEMANO MUCHAS GRACIAS piratariv@hotmail.com
SOURCE: Transcend external hard drive not working.
Contact Transcend Support:
support@transcendusa.com
Posted on Jun 09, 2008
pankaj_dic
  • 1250 Answers
SOURCE: detection problem
check it on other usb ports, also replace the usb cable
Posted on Oct 07, 2008
  • 21 Answers
SOURCE: My Transcend StoreJet 320 GB USB 20 Hard Drive is
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Posted on Jun 22, 2010
  • 1705 Answers
SOURCE: my external hard disk 320 gb storejet is not
You'll have to work your way through the various options but using the device manager menus and options, you need to give your drive a name or letter incator.
Avoid A:, B:, C:, D:, E:, F:, or G: depending on how many HDD and Disk drives you have.
Posted on Jun 28, 2010
  • 297 Answers
SOURCE: Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
Posted on Jul 06, 2010
No funciona bien mi computadora de mesa
Primero verifique para ver si puede arrancar en modo seguro presionando F8 varias veces justo cuando se inicia el equipo hasta que el menu de inicio aparece. Cuando el menu de inicio aparece seleccionar "modo seguro con funciones de red". Si puede arrancar todo el camino hasta en el modo seguro, entonces usted tiene un problema de controladores. Lo mas probable es que usted tendra que instalar la tarjeta de video o los controladores del chipset de modo seguro.
Buena suerte!
Jun 11, 2012 | HP Computers & Internet
Hola, mi quemador dvd modelo GH22NP21 no me quema los dvd porque? los cd si los quema, pero los dvd no. tengo windows xp sp2 con 248 ram, lee el dvd y guada la imagen en disco duro al momento de insertar...
Los quemadores de DVD cuentan con dos unidades de laser. Un laser es para quemar y leer discos DVD. El otro es para leer discos CD. Es muy común que el uno o el otro falla. Si el aparato todavía está bajo la garantía, puede Ud. pedirles quemador nuevo. Si no, tal vez haya llegado la hora de comprar un nuevo. Lo bueno es ya no cuestan mucho... meno de $30 por quemador de buena marca.
Mar 14, 2011 | LG GH22NP21 DVD-Writer - Internal...
EN LA PORTATIL ACER ME LEE EL DISCO SIN PROBLEMA, PERO CUANDO CONECTO EL DISCO USB PORTATIL VERMATI EN MI CPU CORE 2 DUO QUADZ ESTE NO LO LEE
Apreciado endor74,
Tu disco duro externo podria estar averiado o tener la tabla de ficheros corrupta. Por favor descarga la siguiente aplicacion de Seagate para verificar si es por motivos de hardware:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Si no te indica ningun problema de hardware, te recomiendo que utilices la siguiente aplicacion de OnTrack para intentar recuperar los datos todavia accesibles:
http://www.ontrackdatarecovery.co.uk/data-recovery-software/easyrecovery-lite/
Si no aparece ningun dato como accesible y recuperable, entonces solo queda la opcion de formatear el disco de nuevo. Te recomiendo esta guia que puedes seguir paso a paso para formatear el disco:
http://www.ehow.com/how_6026_format-hard-drive.html
Cordialmente,
Eddie Knight
Dec 28, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Aparece un ipod triste en la pantalla de mi ipod de 20 Gb
eso pasa cuando la unidad de disco duro ( hard drive) lla no funciona/ sirve. Puedes comprar uno disco duro nuevo e instalarlo tu mismo. pero no vale la pena pagar para arreglarlo por que cobran muy caro
Dec 13, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Muchas gracias mi problemas es que mi presario 700 no reconoce ningun disco duro y ya hsta le he cambiado la tarjeta done va el disco duro montado que puedo hacer, no se apresia ninguna anomalia en la...
Pon tu disco de instalación de Windows en la unidad y reinicie el equipo. Al arrancar, presiona F2 (o F12) y establecer la secuencia de arranque para "arrancar desde el CD" Instalar Windows programa detectará el disco duro e instalar el sistema operativo en ella. Si no lo hace, el disco duro ha fallado.
Mar 29, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
Tengo una DN hd2500 y se bloquea
bueno, la cosa esta asi, basado en lo que a mi me ha sucedido, yo uso la dn2500 y  le doy mucho uso, a mi me *** ese mensaje varias veces, db save ng! , cant acces, eso es cuando tu disco duro esta fallando o ya murio o no lo puede encontrar, pero cada ves que me paso eso fue llegando al lugar de trabajo, me volvi loco , desconecte el teclado y la volvi a prender y se solucionaba hasta que un dia no arranco mas, entonces saque el disco duro interno y lo quise poner en una caja para copiar la musica a otro disco duro, hecho esto volvi a poner el hd en su lugar y funciono, yo creo que es un tema de los conectores, pero tambien podes ir a utilidades y probar hacer una base de datos nueva. lo importante es sacar la musica que tenes ahi, despues te compras otro disco duro($40) y lo cambias por el que esta ahi adentro o lo usas por usb externo, recuerda que el usb externo tiene que estar formateado en fat 32. aca esta mi email por si necesitas algo matosfilms@gmail.com
May 04, 2009 | Denon DN-HD2500 MP3 Player
Parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Mar 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
47 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
