Question about Whirlpool Dryers
No Heating - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 14, 2010
  • nudup35 Oct 18, 2010
    my dryer used to have 3 wires on plug at old place at that time my 220 plug bured up and burnt my plug i replaced plug and three wire cord it worked afterwords bu still took two hours to dry my new place has a 4 wire plug which i wired and dryer runs it just got longer to dry and takes 4 hours to dry also i used to see a orange light whn i opened dryer now i dont i olny feel heat hope this helps is contenuity where it gives a tone when it has a complete circuit????
    thanks David
My machine stopped heating but everything else functions. Can that be repaired?
There is an element in the bottom.
Google
make model element
They appear to be available
Find Bread Maker Machine Heating Element ' eBay www.ebay.com > ... > Small Kitchen Appliances > Bread Machines Bread Machine Parts Finder is the place to find a Heating Element for your breadmaker. Bread Machine Parts Finder has a breadmaker Heating Element ...
Bread Machine Heating Elements - By Bread Machine Parts ...
www.breadmachinepartsfinder.com/catalog/25 Element-ABM300, Welbilt Bread Machine Heating Element ABM300, $9.99. Element-ABM300, Welbilt Bread Machine Heating Element ABM300-1, $9.99.
Bread maker Heating Element ' Bread Machine Parts Finder
www.breadmachinepartsfinder.com/taxonomy/term/696 Skip to main content. Bread Machine Parts Finder logo. Main menu. Home · Comments. You are here. Home. Bread maker Heating Element. Subscribe to Bread ...
Bread Machine Heating Element - Alibaba
www.alibaba.com > Home Appliances > heating > heating element Bread Machine Heating Element, Buy Various High Quality Bread Machine Heating Element Products from Global Bread Machine Heating Element Suppliers ...
What To Do If Your Bread Maker Stops Working? ' Mr ...
www.mrbreadmaker.co.uk/.../what-to-do-if-your-bread-maker-stops-wor... Apr 12, 2013 - Read our guide on dealing with common bread machine problems. ... are colder and the heat element is not working right then your bread will ...
Morphy Richards Breadmaker Parts ' Partmaster
www.partmaster.co.uk/morphyrichards/breadmaker/catalogue.pl?... Morphy Richards Breadmaker parts - repair your Morphy Richards Breadmaker with a Breadmaker spare part from Currys Partmaster. Worldwide and Next Day ...
Morphy Richards 48280 FastBake Bread Machine Heating ...
www.fixya.com > ... > Morphy Richards 48280 FastBake Bread Machine ...heating element for my SDYD 250 bread maker ? After three uses, the unit no longer heats up......I think it is either a bad control board, or a defective heating ...
Breadmaker Spares ' Spares & Accessories
www.morphyrichards.co.uk > Spares & Accessories Buy a Morphy Richards Breadmaker part. Spare parts for Morphy Richards Bread machine.
and a video of how to change.
How to replace the element in a breadmaker - YouTube
How to replace the element in breadmaker
Feb 06, 2016 | Kitchen Appliances - Others
It's not heating and we've replaced to different heating elements
the dry is not heating up. we replace the heating element and thermostat and thermal fuse., It sill doesn't heat up
Nov 10, 2011 | Amana ALE866SB Electric Dryer
Lg dishwasher ldf6920st not heating/drying dishes What is the part number for heating unit or retro fit kit?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jul 27, 2011 | Dishwashers
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryers Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
