Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark x5100 New computer with Vista on it won't let me install my lexmark x5100 on it? can;t find no updates help shows that I have the newest driver and that its working properly however it won't print. Get message that it can't communicate with computer. I have unplugged the USB and replugged it in, tried turning the power of, waiting for a few minutes and then starting again, then tried doing a restart on the computer but all to no avail. HELP !!!
  • Anonymous Jun 04, 2008
  • Anonymous Jun 13, 2008
    Use the CD to install to new computer with Vista. When I try to print it says cannot communicate with the printer. Tried reconnecting cables, rebooting -- nothing helps.
I keep gettting an error message "spooler service stop/failed". I HAVE UNISTALLED...REINSTALLED I'M TIRED
Posted on Aug 25, 2008
Uninstall all drivers for the printer, reboot computer with printer plugged in and it will tell you that you have new hardware. It will ask you what to do so you tell the computer to find the driver for you on the web. Install the driver and you'll be up and running. Do not install drivers off of the disk as they are for xp and will not work with Vista.
Go to Lexmark support website and select download software. Search for your printer model and download the software needed to work with Vista.
Posted on Jun 14, 2008
Cant lexmark x5100 to windows 7
Hi James,
You cant install the printer on a Windows7 Operating System platform because there are no support drivers for the same.Learn more on this Lexmark support site.
Hope this helps.Thanks!
Dec 19, 2011 | Office Equipment & Supplies
I am trying to add my printer X5150 to my new hp laptop dv7-4177 and as it is loading it comes up to say that it does not have English every other language except English I did't have that problem with my...
I recommend you use the Lexmark X5150 driver from the Lexmark website. But first, make sure there are no existing Lexmark X5150 driver on your computer. Go to the Start menu -> Programs -> Lexmark X5100 Series -> Tools -> Uninstall. Reboot pc when prompted.
To reinstall, click on this link Lexmark X5150 Drivers.
Then click on FILTER.
Click on the Complete Driver under Recommended Downloads. Download, execute the file and follow the instructions on the software. NOTE: Use Vista driver in Windows 7.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark X5150 All-In-One InkJet Printer
I ave a lexmark 4200 series a three in one... it worked good on my other computer with windows xp cant get it to work with the new one with windows vista says it is not plugged in the computer even when ya...
I had the same problem and can give you the exact instructions I was given and used to fix mine. I am not a tech guru so do not have all the underlying reason about why.
A link will be provided. It is the place to download the updated version of the Lexmark Driver for Vista, whether it be 32 bit or 64 bit, or even Windows 7, etc.
The other thing I had to do was to update Vista; in other words short of a full reinstall of the Vista software is the only way I could get it to work. Do not plug the cable for the Lexmark hardware in until the Vista has completely finished doing the update. If you do update instead of full install with the Vista disc, you can still keep all of your docs, etc.
Link for Lexmark updated drivers:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
1. So to recap: delete all of your printers in control panel.
2. To a complete update with your Vista installation disk.(Make sure the cable to the Lexmark printer is unplugged until Vista finishing installing itself.
3. Install the updated software from the Lexmark link.
4. You may still have to use the Lexmark original installation software to tweak some items for the different applications such as fax versus scanner versus copy, but the main problem for me was no printer or scanner working. I do not use it for fax since I have Efax, so that was not an issue for me.
Good luck.
Sep 06, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't get my lexmark X5100 series all-in-one for XP systems installed on my new Vista system
Please visit the http://downloads.lexmark.com
then select the model and vista version and download and install the drivers
regards
http://www.mytechguru.us
Dec 16, 2008 | Lexmark Office Equipment & Supplies
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
Computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark 4270 will not install
I believe this will fix it for you as it did for me. I have a Lenovo laptop that updated from XP to Vista and the Lexmark 4200 X4270 All in One Printer would not print or scan. I had to do the following:
1. Delete all printers in control panel.
2. Do full update with Vista install disk
3. Make sure cable to Lexmark is not attached to Laptop until Vista does full update
4. Download the updated Lexmark Driver for whichever version of Windows you are running from the link provided below.
5.Install item in #4
6. Plug in cable to Lexmark and put the Lexmark SW installation disk in and it should finish itself for you.
Link:
Apr 15, 2008 | Lexmark X4270 All-In-One InkJet Printer
Unable to install lexmark p4350 into window vista
For both of you. Update Vista through windows update service. Even if this is a new printer the software CD may already be out dated. Go to Lekmark (After updating Vista), & download & install the latest software drivers for Vista. (Click the link provided). http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
If Vista still fail to see the printer call Lexmark. (Number in manual). Or click on this next link for help.
Mike
Apr 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark x5100
I have lost the installation cd to my lexmark x5100 how can I get it to install?
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
