Canon np6412 need to reset error code e002 - Office Equipment & Supplies
  • lsbm Oct 13, 2010
    This did not help be reset the error on Canon NP 6412 Copier
  • lsbm Oct 14, 2010
    I finally got ahold of a Service Technician that walked me thru the process of resetting the Canon NP6412 Copier. The main board did not need to be replaced. This is bad information and want a refund.
  • 8,197 Answers
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Posted on Oct 13, 2010
  • Jyackle5
    Jyackle5 Oct 13, 2010
    I sugest that you replace the main board. That is most likley the problem.
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Error code appear my Canon Xerox 405 e.i. e002. Please reply me how to solve the problem step by step. Please reply as early as possible. Thanks, Rajes Acharya
The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right
To enter the service mode:
1) Press the asterisk key ' ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' ' on the control panel
Hope that helps!
PS If not you have problem in fixing unit, probably the fixing thermistor and need to be replaced.
Jun 24, 2011 | Canon imageRUNNER 400S Copier
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
Code error E002// Icanot reset it
try this open the front cover on the left hand side try to look for small hole on the hole insert paper clip and press a little bit you will see asterisk on the lcd panel then press *4* then browse for resetting error then you can reset fixing error(E002)
Jul 11, 2009 | Canon NP 6035 Copier
Canon PC-850 E002 Error Code
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Mar 19, 2008 | Office Equipment & Supplies
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
102 people viewed this question
jasbo
jasbo
