Question about Stanley Staple/Nail Gun Elec
What am i doing wrong if staples do not load - Stanley Staple/Nail Gun Elec
  • Stanley Master
  • 7,733 Answers
Try a support here. at the bottom page
Posted on Oct 14, 2010
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
How do I load staples? Or could I have the wrong staples?
The black square piece pushes in then will unlock and slide out.
make sure to purchase staples that match.
example may use T 50 , or other sizes
Oct 01, 2016 | Tools & Hardware - Others
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
The staples do not go far enough into the sdlide chamber to allow the hammer to strike the staple. The staples do not show in the openning when it is loaded. What am I doing wrong? I have a model D51420 18...
I believe on that model you have to release the magazine latch, pull the lower half all the way back, load the staples into the upper half of the magazine, then close and latch the lower half. The staple pusher and spring are located in the lower half so the staples need to be in front of that for them to be properly pushed into the nose. Also make sure you are running the correct staple. There are 1/4" and 3/16" narrow crown staples out there and they don't interchange. The staples should slide freely in the magazine when they are loaded.
Jul 17, 2011 | Dewalt Air Tools & Compressors
I loaded the stapler as described above. Now I hear the staples sliding around inside the casing. I loaded as many staples as the gun will hold. I pressed the handle down and three staples came out at...
You need to load just enough staples in it that when you put retaining spring and clip back in that it will let catch on back of spring to go into slot in frame. I hope this helps. Thank you
Nov 19, 2010 | Arrow T50P ARROW STAPLE GUN
I have a Pro Sharp Shooter TR 200. WHILE I HAD TROUBLE loading the staples in, I think I have them in properly, the staple cartridge door is closed but the staples aren't coming out. What am I doing...
Make sure that you are using staples made for this tool. Remove the staples and look for a jammed staple at the drive head which will block further staple movement. Make sure there is spring tension at the rear of the staple row when the slide is closed. Hope this helps!
Oct 15, 2010 | Stanley Garden
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
I'm stumped -- I just bought a Stanley Heavy Duty TRA700. I took the "safety" off (the wire loop that holds the handle down), pinched the lever on the back and slid out the tray the staples go into. I...
The question here is what are standard staples in YOUR opinion? Are they designed to be used with this staple gun. What length are the legs of the staple 1/4" or less.
You cannot just use any staple in these guns They have to be the correct type either stanley or Bosh
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Stanley Chrome Hd Staple Gun Tr110
How do I load this Stanley Staple Shooter Light Duty?
This doesn't load like normal staple guns. Go to the end of the stapler and pull out the locking device with the spring on it. Then turn the staple gun upside down so you're looking at the bottom of the gun. See, there is now a little channel exposed. Drop the staples in this little channel with the points of the staples pointing towards you. Keep the staple gun upside down and reinsert the locking device which will compress the staples. PRESTO! Ready to use.
Aug 26, 2009 | Powerfast Stanley TR110 Light-Duty Staple...
Got it loaded now it won't shoot
I have a similar staple gun and I figured out I was loading it wrong. If you are loading it where the spring is, like I did, it won't work. there should be another area close to that spring opening that you put the new staples in.
Oct 02, 2008 | Black & Decker 5700 Powershot Forward...
Stanley Staple/Nail Gun Elec Logo
66 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
