Question about GE 24 in. Profile PDW9200J Built-in Dishwasher
How do I install cable asm - GE 24 in. Profile PDW9200J Built-in Dishwasher
  • stonea68 Oct 13, 2010
    the cable I am replacing is one of 2 cables on the bottom of the door that prevents the door from falling to the floor when you open it
  • stonea68 Oct 16, 2010
    I see the part in the diagram I just need to know how to install it
    President:
  • 1,891 Answers
I belive that what is the cable assem is the door spring cable and nylon link . so you will have to in order to make it easy remobe the two screws under the top edge of counter this should let you slide the dw out enough to see the sides. if only one side needs replace ment then look at the side that is in tack . a picture is worth a thousand words .. hook the nylon to the door bracket and the open end of cable to the nylon and then strech the spring to the hook or barcket . adjust tenson as needed for weight of door . . heaver door add more tenson . but copy the other side . . ps its best to replace both sides . at the same time . this will prevent you from doing this nest week .. hope this has helped m and thanks for using fix-ya . mm this is a very common repair and is not too hard . mm
Posted on Oct 17, 2010
  • GE Master
  • 3,247 Answers
It is best to refer this diagram. The cable asm is item 733 and you can see the assembly very clearly.
Please rate this solution from me if you find it useful. Otherwise post a comment and I will try and clarify further.
It is important that you please acknowledge the solution to help fixya serve you better in future.
Posted on Oct 14, 2010
  • 4,323 Answers
Hi
Please confirm if you want to install ribbon cable that connects the keypad membrane or the cable which is hooked in the MIDDLE hole of the door. The door panel covers the main control board, detergent cup, wire harness, Smart Dispense bottle, Smart Dispense detergent sensor, and Smart Dispense pump.
The outer door panel is held in place by 12 screws (5 Phillips head screws per side and two 1/4-in. hex head screws at the bottom). The esutcheon keypad is held on by 4 screws.
Note: When removing the outer door panel, be careful not to remove the 4 screws (2 per side) holding the escutcheon to the door assembly. Remove these only to gain access to the control module, active vent, fl apper, and door interlock switch.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 13, 2010
How to replace water tank on ge pfss6pkxcss refrigerator
Here is a link to the instructions per the Service Manual=> GE PFSS6PKWASS Water Tank Removal and Installation Instructions If you have questions I will be here to assist you, Thanks Sea Breeze
WR17X12468 Asm Water Tank and Here=> WR17X12468 Asm Water Tank
Jun 03, 2013 | Refrigerators
I install a driver but the computer did not dedect the sound
Make sure that the drivers are correct and they should be compatible with the operating system that your computer is running.
You can get the drivers by visiting the website of your computer's manufacturer. Make sure to select the correct model of your computer and the operating system. The drivers will be presented to you then install them.
David
Jan 01, 2013 | IBM Levono ASM 92P1132 ASM 92P1138 ASM...
Dome lights don't come on when you open the doors but light works when you push button on dome.
The dome lamp has a switch that can be put into several positions. "Door" "Off" and "On" If you want the light to come on when you open the door then you must have the switch in the "Door" position.
The "Off" position will only let the dome lamp work when you override it with the dash control and the "On" position will leave the light on at all times - door open or not.
Dec 18, 2010 | Hyundai Santa Fe Cars & Trucks
How difficult is it to replace the fuel pump on a 1998 ford explorer
it is in the fuel tank. you have to disconnect the fuel inlet hose at the tank, 2 tank strap bolts while supporting the tank with a jack. then use the jack to lower it enough to reach up and remove the "quick disconnect" fuel lines from the sending unit/pump asm. (special tool required) Then drop it down, remove the retaining ring from the top of the tank and pull the entire sending unit/fuel pump asm. straight up and out...reverse procedure to install the new asm.
Jun 26, 2010 | 1998 Ford Explorer
Fuel pump removal and instalation
jack car up on lift, next is to dissconect lines to tank, all lines the fuel line and the evap line, dissconnect electrical connector to pump asm, when removing fuel lines wear safty glasses there may be a little prease in lines,nexy support tank,if it has a drain plug then drain the gas out,remove the filler neck from tank,remove the straps that hold tank lower the tank, remove fuel pump asm, lock ring, then remove pump asm, reverse instruction to install new pump asm, hope this helps.
Mar 02, 2010 | 2003 Chrysler PT Cruiser
How do you replace the passenger side low beam on a Pontiac Grand Prix '07? I can't get to it from the back, so I'm wondering if there is a special tool to take off the front lens.
raise the hood. lift upward on the headlamp retainer(its a off white color tab right behind the lamp asm.in about the middle of lamp)pull the headlamp asm. outwardenough to release the headlamp asm from the upper fascia support.position the headlamp asm. away from the vehicle body to access the electrical connector. disconnect the electrical connector from headlamp asm.remove headlam asm. from vehicle. remove headlamp bulb /socket from the headlamp ,by turning counter clockwise. remove headlamp bulb/socket from the headlamp asm. install new bulb in socket and reverse procidure .
Feb 22, 2010 | 2007 Pontiac Grand Prix GXP Sedan
Access server manager 3.6
The DECserver 732 is a high-density, high-performance asynchronous device and remote access server that provides 32 MJ8 (RJ45) serial ports. The DECserver 732's serial ports support either of two sets of software-selectable four-signal modem control signals. The DECserver 732 has AUI and 10BaseT Ethernet connectors. The DECserver 700-16 supports up to eight sessions per port and speeds up to 115.2 Kb/s per port. The DECserver 732 has an external FLASH socket for the customer-installable flashcard. When installed, the flashcard allows self-booting operation. The DECserver 732 runs DECserver Network Access Software (DNAS), which delivers multi-protocol support for TCP/IP, IPX, and AppleTalk networks. DECserver 700 units are designed for tabletop or rackmount configuration
the u need to check these site for more info:
http://www.vnetek.com/s-137-digital-networks.aspx
Jan 05, 2010 | Digital Products Digital DECserver 732...
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
77 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
