Question about Hitachi 32HDX60 32 in. Plasma Television
I have a problem with my Technika 32" plazma t.v. I was watching it with my daughter when it turned itself off to standby. I left it for a while then attempted to turn it back on- every time I did so it would switch off to standby again, I have tried using it manualy and the same thing happens. I have tried taking out all skart leads but to no success, please help I have had the t.v for only three years! thanks. Yasmin.
    Top Expert:
  • Hitachi Master
  • 40,263 Answers
The power supply may be failing.
Posted on Jul 15, 2017
  • 69 Answers
SOURCE: Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Posted on Dec 31, 2007
  • 4402 Answers
SOURCE: tv turns itself on and off
Convergence amp ic bad
Sony Convergence
Posted on Jan 28, 2008
  • 563 Answers
SOURCE: CP-S335 popping noise when powering on
Hi Eva
A Projector does'nt like being switched on and off all the time , if you are going to watch a couple of movies - rather leave the machine running all the time - this will also help you to get more hours out of your lamp - and that's a promise.
As far as the noise is concerned - it is most probably just the machine that was not cooled down properly at that stage.
Posted on Apr 03, 2008
  • 431 Answers
SOURCE: My hitachi 57f500 turns itself off after 3 hours of use. Turning it back on restores the picture,
Hi I am Vortash
There may be actually nothing wrong with your set ? .......
This set has an anti surge protection circuit and it is designed to shut down should the incoming power peak above 240 volts or more , is this happenig at random times or around the same time in the evening or day it may be that this safety device is protecting the set .. sometimes local area transformers peak at the time of most consumer requirements this may just coincide to when you sit down to watch tv .. however if it has a habit of doing it at different times during the day .. then this safety circuit may be at fault and require an engineer to service the tv and check for poor components that have changed value .. It explains this is in the manual if you do not have one for your set you can download one for free from hope this is of help regards Vortash
Posted on May 20, 2009
I have a 60V710 that will not power up at all. No lights on the front panel, no sound of anything happening when I click on tghe front power switch
Posted on Sep 29, 2009
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
Technika lcd40-920 turns on they turns itself off after 20 mins then keeps turning itself of and on for a while until eventually the on and standby button just flashes alternate colours
A through check should be done make sure about the fault. Power supply section is working, as you reports. Otherwise, there will be no power ON function. The main board might have the fault; shorted or damaged components.
Jul 12, 2012 | Televison & Video
My Technika freeveiw hd box keeps going to standby could it be because it is turned off every night, does it need a perminant power supply?
freeview boxes generally update around 3am every night so yes you maybe correct as to the cause of it going into standby. It has to go into standby to update itself, same as when windows cant update because files are in use. try leaving it in standby at night and see if that resolves the issue
Mar 04, 2011 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
I also have a technika 19dvdid-207 tv stuck in standby mode or blink mode. Was watching BBC1 then screen went off. Have changed batteries in the remote.
try a remote reset by pressing every single button on the remote starting from the very top left hand button and pressing every single button - if that dont work ring the helpline with your reciept and they can sort you out from there.
Jan 03, 2010 | Televison & Video
Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Sep 01, 2009 | Televison & Video
Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Jul 13, 2009 | Daewoo DLP3212 32 in. LCD Television
Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Jul 09, 2009 | Televison & Video
Tv won't turn on, we were watching the tv and it turned off by itself and wouldn't turn back on. electric is good etc.
If there is no standby light then it is likely to be the fuse inside the tv. If there is a standby light then it could be many various things.
Jun 16, 2009 | Protron PLTV-32 Television
Hitachi 32HDX60 32 in. Plasma Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
