Question about IBM Lotus SmartSuite for PC
I have Lotus Smart Suite, Millennium Edition on my IBM Think Pad. I use Lotus 123 spreadsheets. Just recently, one of the folders will not open. Up comes an error message saying "error opening or saving file". This folder is important to me. Can you help please?
  • fandw1 Oct 15, 2010
    Hi - I have tried to try your first solution..bytefix. However, when I click on bytefix.exe, the black box area comes up in flash and disappears. It won't stay put and let me write the file name in it. Any ideas?
  • 496 Answers
I assume that you are using Windows as your Operating System. Please note that this error is caused when the Lotus 123 file become corrupt or the file becomes damaged. It is normal and can happen to anyone any time. I am sending you some links. From these links download the Lotus 123 file repair utilities or software. Please download them and try to repair your Lotus 123 files. Carefully download and install them and then work out. I am giving the links in order of my preference.
http://www.s2services.com/123-tools.htm
http://s2services.com/lotus123freeware.htm
Please note that the above two repair tools are free the following one in called " LotusNotesRecovery 1.0.0642" This tool is paid and I find it very remote that you might need it because it is used in terms of Data Base corruption. If you can access other Lotus 123 files in the same DB then definitely the downloaded tools from the above links will suffice your requirements.
http://www.freedownloadmanager.org/downloads/lotus-123-file-repair-43011.html
Good Luck!
Posted on Oct 13, 2010
Lotus 123 problems
Microsoft Excel should open your old Lotus files.
Go to File > Open > Select Files of type: Lotus (*.wk?) and select your Lotus file.
Alternatively you could install and use OpenOffice spreadsheet or LibreOffice Calc and open your Lotus files.
Jul 24, 2014 | IBM Lotus 123 Millennium Edition 9.5...
In Lotus 9.5 Millennium Edition, cells have become frozen and can't be moved with the arrow keys. How did I cause this and how do I unfreeze the cells?
John,
Occasionally I have found that particular cells become a problem. The following has worked for me and could be a way to fix your problem:
Assuming the problem cell is in Column D, insert a new column to the right of column D.
Copy Column D and paste it into Column E (the new Column you inserted). Delete Column D. Now check if that problem cell works OK.
Mar 12, 2014 | IBM Lotus 123 Millennium Edition 9.5...
I have ancient lotus 123, approach, amipro and need to fit them into the new lotus smartwuite. How
well an ancient is fine what is not fine is that xp you installed is most likely not compatible with older versions, which were 3.x and early xp ok
time for an upgrade methinks.
May 29, 2012 | IBM Lotus SmartSuite 9.8 Millennium...
Problems opening lotus 123 files, very slow
I have all my Lotus files on a server and am not experiencing this problem. Did you install the desktop version or the network version. Mine is desktop and I get my files off the server. Works well.
Feb 11, 2010 | IBM Lotus 123 Millennium Edition 9.5...
Cannot open program. Error message "Lotus 123 Application has encountered a problem and needs to close". Worked fine last week.
Are you running Lotus Notes as well? There is a known compatibility issue and a patch for this.
Have you upgraded or installed new software recently ? Version 9.5 is not the latest version and has some issues with newer software.
Nov 17, 2009 | IBM Lotus 123 Millennium Edition 9.5- U...
Want to load lotus on to a vista system.....can I??
  • The Notes 8.0 feature release (released in August 2007) was fully tested and is supported with Windows Vista.
  • The Notes 7.0.3 maintenance release (released in October 2007) was fully tested and is supported with Windows Vista.
  • Notes 7.0.2, the in-market Notes release (shipped in September 2006) when Vista was released on January 20, 2007, is supported on Windows Vista. Releases prior to Notes 7.0.2 are not supported on Windows Vista.
  • Due to the broad changes in the Windows Vista release, and no more 6.5.x Maintenance Releases, Notes 6.5x is not supported on Windows Vista.
Nov 15, 2009 | IBM Lotus 123 Millennium Edition 9.5...
My lotus file is corrupt no run and run time error
Corrupted lotus file may be repaired with the help of nsf file recovery tool
Tool http://www.recoverytoolbox.com/lotusnotes.html will effectively aid you
Apr 27, 2009 | IBM Lotus 123 Millennium Edition 9.5- U...
How do you get the bottom of the page without
Try any of this.
<End> OR
<Shift><End> OR
<Ctrl><End> OR
<Alt><End>
something out of this should work
Apr 14, 2009 | IBM Lotus 123 Millennium Edition 9.5...
Computers & Internet Logo
98 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
