I have a Martin heater model# V6835 and need to convert it from propane to natural gas. I know that I need to change the orifice. Can you tell me how or preferably recommend a web site that gives me step-by-step instructions with diagrams?
  • 210 Answers
SOURCE: LG gas dryer to convert in propane
To get the orfice you have to contact LG. The part number is (propane gas) 4948EL4002b it runs around $20
Sgt 48
Posted on Jun 11, 2008
  • 182 Answers
SOURCE: I want to be prepared
not only do you need the nozzles....you will need the spring changed in the gas valve and a manometer to set the proper gas pressure output from the valve.If you change the jets only you could do alot of damage to your furnace.
Posted on Sep 23, 2008
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 14, 2009
buxbud2
  • 3 Answers
SOURCE: Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Posted on Apr 18, 2009
If I need to convert my Martin unvented fireplace from nature gas to lp cause I have propane already
You need a conversion kit. The igniter orifices are different for LP. Go to the stove store and ask for one for your model.
Dec 14, 2016 | Heating & Cooling
I got a global warming heater model FB-5 propane can I change it to a natural gas?
You would need a kit to convert ,you have to change the orifices and the regulator to Nat gas .Goole the make and model to see if it will convert some do not .
Dec 09, 2016 | Heating & Cooling
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
How do I convert my rheem water heater from lp to natural gas model#21vp40-1p
Call Rheem
Generally the company does not support changing type of gas since propane burns much hotter and has more pressure than natural gas.
You need different gas control valve, and need cast iron burner and orifice than matches that specific gas control valve.
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 14, 2014 | Water Heaters
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your self....you need to get rid of the Propane regulator....you need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
