Question about GE GTS18FBRWW Top Freezer Refrigerator
GE refrigerator Model GTS18FBSARWW Don't have manual, as it came w/the condo. Don't know how to clean the coils or how to get to them, either. Thanks.
  • 316 Answers
The condenser coil is located underneath the refrigerator on most models. YOu can access it from the front, or in some cases, in the rear. To access it from the rear, after pulling it away from the wall, you will have to remove the machine compartment cover screws and the cover itself. If it is the type i believe it is, it is called a no-clean condenser, but they still need occasional cleaning. It will be a barrel shaped condenser on the right side of the machine compartment. A good refrigerator tip for anyone looking to clean the condenser is to make sure you turn the fridge off or unplug before cleaning it.
Posted on Oct 13, 2010
Gts18fbsarww First the food in the frig turned warm and another day and half later the freezer side is warm. Any ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | GE (GTS16BCS) Top Freezer Refrigerator
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
I have a ge refrigerator MODEL NUMBER GTS18FBSARWW AND THE FREEZER IS NOT COOLING completely
i have a ge fridge and the frezzer is working, but the fridge isnt keep food cold enough
Dec 28, 2010 | Refrigerators
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Apr 04, 2010 | GE Refrigerators
Not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Please tel me the age of my fridge: GTS18FBSARWW TL3464 thanks
According to information I have been able to glean from the NET your refrigerator model is two to three years old.
May 09, 2008 | Refrigerators
GE GTS18FBRWW Top Freezer Refrigerator Logo
783 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
