Question about Hotpoint Ultima WDM73 Front Load Washer / Dryer
Go to do a programme but f10 keeps flashing and does not dry closhes cleaned filter hotpoint ultima
  • 171 Answers
Hello there,
this f10 error code means problem with thermostat or heating element. What you need to do is check both of them for continuity.this will require a multimeter. If you have one set it to OHMS range and take off one wire off each stat and then test for continuity.
If you do not have a multimeter you may want to call a professional to come and do it. Or if you do have one and you are doing it yourself it is more often that it is the thermostat not the element they rarely go on this unit.
You can always refer to your owners manual and if you don't have it anymore or lost it here is a link to help you with that.
www.manual.Pronto.com
Posted on Oct 13, 2010
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
F-04 on hotpoint ultima can you tell what this means please
"F04" on the display panel before the programme ends. Have you cleaned the filter out on the pump
Apr 06, 2013 | Hotpoint Washing Machines
My Hotpoint Ultima Washing machine - When I switch it on all the lights keep flashing and I can't get rid of them !! When the machine then starts the cycle it still flashes but then stops half way and says...
I would advise you to check the drain outlet hose for a possible blockage, or the pump itself could be blocked or faulty.
Drain any surplus water in to a bucket or similar before removing hose or pump.
Also try resetting washer if there is a reset button, hold it in for at least 3 seconds, this should clear any programme held in the memory.
Hope this helps.
Feb 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima CTD80
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
94 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
