Question about Rheem Water Heaters
MODEL 8MV50-2 B DOESN'T SEEM LIKE IT IS FILLING UP WITH WATER; WATER IS ONLY WARM NOT HOT.
Bosch aq 125
Check for crossover, aka cross connection
http://waterheatertimer.org/Crossover.html
Install ordinary tank electric water heater for $250 and solve problem quick, sure and cheap
Jun 06, 2013 | Water Heaters
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
Water heater
Hey Debora.
Give me more information. Add a comment.
What type water heater? Brand, type and model appear on label on side of unit.
Is this a gas or electric powered?
What exactly is happening? Water too hot. Water doesn't stay hot very long? No hot water?
Add a comment please.
Sep 08, 2012 | Water Heaters
Premier Plus Model#MHE62-30H-045DV Ser#45T421608 I just purchased this hot water heater.I had it professionally installed by a plumber.We had hot water before I went to bed but when I woke in the morning...
sounds like you have a power problem. or worst than that a leak . So lets look at the leak first. Turn off the water supply at the water heater on top. This valve should be on the cold side of the heater on top.
Turn it off, check and see if you have pressure in the house by turning on a faucet. It should run for a second then stop. That is good if it does. Leave the valve off on the heater and check that your breaker is on. Reset the breaker by turning it on and off.
Wait about 2 hours turn the heater back on and check to see how hot the water is hot then you might have a leak in the building. If there is not or little hot water. Check the wires where it connects to the water heater. You might only have one wire that is connected right.
The best thing to do is to get a amo meter and check to see if you have 220 if you dont have 220 you will not warm up the water the way it should.
Thanks Richard
Sep 07, 2011 | Premier Water Heaters
Not continuous hot water and radiators
If it has a distance from the boiler to your use the water in the lines and the lines themselves ahve to warm up before you will get hot water, Let me know more if this dosnt help. Please rate me as high as possible if it does help you understand your trouble.
May 31, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water
Is hot water present when opening the drain valve. Use a bucket to catch the water. Adjust thermostat from high to kow then prefered detting. Make sure hot water out line does not have a closed valve. If gas, ck pilot. If electric, elements may be damage if heater was powered up before or while initial filling.
May 11, 2009 | Water Heaters
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Water Heaters Logo
149 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
