Question about Audiovox Xpress Satellite Radio Receiver with Vehicle Kit
Can not get a link to any satellite channels; everything else works; need an owners manual
  • 44 Answers
Not sure if this is exactly your model but worth a try:
http://www.xmradio.com/pdf/hardware_support/audiovox/Xpress_Rcvr128-7454C_8-01-06.pdf
Posted on Oct 13, 2010
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
I just bought a notebook and I need the owner's manual in English please, thanks
Hi I am providing the Link for your Laptop Support Webpage. You will find EVERYTHING you need there.. OK? Lucky4lynn2 :) p.s. PLZ RATE ME. THX
Mar 15, 2010 | Toshiba Satellite A135-S2276 Notebook
Looking for the owners and service manuals for MOOG ''Satellite''..
Here is the link to the closest information you will find:http://www.pat2pdf.org/patents/pat4050343.pdf It is the schematic. You might try asking for the source for an owners manual at this site:http://makerspace.org.nz/content/moog-satellite-adding-cv-and-gate-out-jacks Apparently they were manufactured by the Thomas organ company. Try this link:http://www.organservice.com/ Let me know if this helped.
Nov 24, 2009 | Music
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
I need an owners manual for the receiver
What channels on what satellite? You should always start with sat G1 channel 3 and rehit. This will map in all the channels the receiver is authorized to get from Motorola.Options 6 5 and the trip counter should go up by 5 and show ~ 4600 channels
After that you need to make sure you are good on the arc. Start with G-1 5 (analog) then go east about 20 counts to C3 channel 7 On both G1-5 and C3-7 you may need to adjust the skew to get the picture.
The same is true for digital channels like those on G3C like TNT, CNN, SPIKE etc.
Once you know you are on the satellite then adjust the skew.
Feb 22, 2009 | Arris DSR922
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not...
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Dec 13, 2008 | Akai LCT2701AD Television
Dbox has gone down
Hi.
Unfortunately the box does not keep a backup of your channel settings and codes. When this happens you need to program channels again. You will be asked to insert the code again.
Try the code here
Try also using box access code 1234 or 0000
If that does not work, you will have to contact the phone number listed in the owner manual, you will get assistance in reprogramming the channels and finding the right codes.
Sep 18, 2008 | Audio Players & Recorders
The code "C66" does not appear in the owner's manual...
there will be a circuitry problem, if you havnt had it long take it back and see if you can get a replacement
Apr 25, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Audiovox Xpress Satellite Radio Receiver with Vehicle Kit Logo
115 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
