Question about Kenmore 57029 Side by Side Refrigerator
I PURCHASED A MODEL #57022 SIDE BY SIDE.FROM THE FIRST YEAR I HAVE IT(2004) I HAVE HAD A SERVICE MAN DEFROST IT 4 TIMES.IT FREEZES OVER THE REFRIGERATOR VENT IN THE REFRIGERATOR SIDE WALL. IT CONSTANTLY SWEATS . I HAVE HAD NOT ONLY TO PAY FOR SERVICE BUT A LOSS OF FOOD EVERYTIME THIS HAPPENS. THE LAST REPAIR MAN TOLD ME THE AIR IS GETTING THRU THE DOOR. I I HAD IT DEFROSTED IN JUNE AND THEN AGAIN IN SEPT.THERE IS A FLAW IN THE MFG. OF THIS APPLIANCE THIS IS SUPPOSE TO BE A FROST FREE FRIDGE.
  • lilakay2003 Oct 13, 2010
    HE APPLIED A APPLICATION TO THE INSIDE OF THE DOOR TO EXPAND THE SEAL.
    compressor coils were cleaned, all others were checked. i don't know for sure about the drain tube., and if the drain tube has anything to do with this problem, that means that from the first year i had this fridge there was something wrong.
  • 760 Answers
Even a frost free fridge with a leaking door cannot keep up with the humidity that enters. Be sure the door gasket is closing fully around door. You can sometimes put a piece of paper under magnetic gasket, and you should feel resistance pulling it out. Also be sure the ice maker door is closing. If it is not fully shut, moist air can enter here. There should be a drain line running to a pan in the bottom of the refrigerator. The hot air from the compressor evaporates this water. If this drain is not open, then the moisture cannot escape.
Posted on Oct 14, 2010
    Genius:
  • 1,478 Answers
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube.
Posted on Oct 13, 2010
    President:
  • 2,047 Answers
The problem with the fridge is repetitive. A frost free fridge is supposed to be devoid of frost. To solve this issue once and for all the best bet is to get the last service man to take a look at it and locate where the air has been coming through. This can be blocked once the space is blocked then the fridge will stop frosting and sweating.
Hope this solution has been helpful?
Why is water leaking into the refrigerator from the freezer?
The defrost drain in the freezer is clogged. The defrost water then overflows and runs down the vent where the cool air enters the fresh food section and makes a puddle on the top shelf. You may defrost the unit over nite or have a tech come check it. If you just defrost it and there is some type of debris in the drain line that will not melt then you will still need a service man. Or if you feel brave, and can be totally careful so you will not get cut remove the back wall of the refrigerator after you unplug it and get some towels and boil some water. Gentle pour the hot water into the area below the evaporator, ( the thingy with all the aluminum fins), You will eventually hear the water emptying into the pan beneath the refrigerator. Once you hear that you can reassembly and resume operations.
Dec 31, 2017 | Whirlpool Refrigerators
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Hi, I am Dennis. The unit leaks water from the vent in the bottom center of the freezer side on to the floor of the freezer and sometimes out of the freezer door to the kitchen floor. Not muck of a leak....
Abesolutely a bad defrost heater. it is too weak to defrost the ice completely, therefore it falls off the coils and freezes on the drain tray. If you dont want to replace the heater you can also just install a drain tube heater that wires into the evaperator fan, it will run constantly as the fan does to keep water from freezing in the tube or tray. All parts can be purchased at http://www.reliableparts.com/ using your model number.
Nov 30, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
The unit freezes up then don't work
OK I'm looking over the manual and as long as the model number is correct RS2630SH you may have only one of three things causing this. I needing to go to another website to confirm the type defrost system yours has. I will send you a manual when I return. It appears that you have a higher possibility of a defrost heater or defrost thermostat defective.I am getting mixed answers on a decision of a defrost control board. Just make sure your model number does not have a different number or letter missing. I will send as much as I can find on your model but checking the defrost heater and defrost thermostat would be the first thing to do. Unplug refrigerator and remove contents of the freezer rear wall. we need to use a meter to check continuity through the defrost heater. If one is bad replace both defrost heater part number DA47-00154A and defrost thermostat part number DA47-10160F.
One model came with a defrost control board but I just cannot find one on that model number so the motherboard controls defrost. I will send manual shortly. Thanks, Sea Breeze
Jan 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
Frig freezes up after a few weeks -- the glass tube looks fine
THERE IS A DEFROST SENSO ON TOP OF THE EVAPORATOR MANY TIMES IT WILL LOOK SPLIT WHERE THE WIRES GO IN THE BACK IF SO REPLACE IT
Dec 19, 2009 | GE GSS22SGM Side by Side Refrigerator
Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Dec 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have had to have my appliance repair man unthaw and unclog my condensation drain 2 times in the last 3 months. The bottom of the freezer freezes and water drips into the fridge. My refrigerator model #...
Three things. First is that your defrost element is faulty, replace. Second, if the defrost element is working there is usually a thin filiament of aluminium which is attached to the element and inserted into the drainpipe, this keeps the drainpipe from freezing up by radiant heat conducted from the element. Thirdly, your main pc board defrost side is faulty and needs replacing.
Mar 09, 2009 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
