For winterize aquamate above ground swimming pool pump see here for information:
http://www.aurorapoolsandspas.com/products/1/1/Above_Ground_Pools.html
It depends if you are leaving the pump outside, if you are the you need to run RV or pool antifreeze through it, however the best thing to do is bring it inside.
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
