Question about Blade 24- Irwin 7-1/4" X 24t Classic Circular Saw 25130
Can you repair a crack by welding the circular saw blade? And if so how? Thanks Mike
  • 7,733 Answers
No because is made of one piece of material and if you weld it it going to bend duo to heat. So buy one!
Posted on Oct 13, 2010
Where can we buy replacement blades?
Circular Saw Blades from Freud Sold Online - Tools Plus
www.tools-plus.com/freud-circular-saw-blades.html
Saw Blades for Less at Tools-Plus.com. Free Shipping on 1000's of Products.
Circular Saw Blades, ALL Sizes, ALL Brands Sold Online ...
www.tools-plus.com/supplies-power-tool-blades-circular-saw.html
Circular Saw Blades for Less at Tools-Plus.com. ... Shop with confidence knowing that Tools-Plus.com is an Authorized Internet Retailer. 3-3/8" Circular Saw Blades .... Saws and Replacement Blades · Automotive Hand Tools and Equipment ...
Nov 02, 2015 | Saws
How do you get a stripped screw out of my 7 1/4 circular saw?
if the head of bolt has broken off get a bolt spot welded to end of bolt in saw. I once had bolts shear off a mulcher and the repair man spot welded bolts onto what was left and unscrewed the bolts.
Jul 16, 2015 | Saws
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
I have a DW357 circular saw. It is running backwords???
It shouldn't be for no reason...... Check that the blade is spinning over the top and down into the wood in the line of travel. Is it possible that the blade is on backwards?
Best regards, --W/D--
please feel free to rate this solution. thanks.
Feb 05, 2011 | Dewalt Heavy Duty 7 1/4" Circular Saw
I burnt up a circular saw trying to cut thick plywood with a dull blade and now it arcs when trying to use it. Is it repairable? Thanks.
I would replace the brushes on the motor, that is the first cause of arcing. The armature may be worn down too. Still a pretty easy inexpensive repair.
Jan 01, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Hi all. i have a circular saw which spins the blade ok untill th blade touches a surface. the blade then stops spinning but the motor carries on without stopping. i have removed the blade and i can touch...
If its a direct drive side mounted then the shaft has broken away from the motor. If is a worm-drive then your gears are worn. Either case, fixing it would cost more than it's worth, but more importantly, nothing is worth more than a safely operating circular saw. My suggestion is to ditch it and buy a new one as an insurance policy.
Dec 17, 2009 | Saws
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Sep 12, 2009 | Saws
Blade 24- Irwin 7-1/4" X 24t Classic Circular Saw  25130 Logo
175 people viewed this question
Top Blade Saws Experts
80stech
Are you a Blade Saw Expert? Answer questions, earn points and help others
