Question about Microwave Ovens
Gaggia trevi sup 018 MR Constant red light though coffee and water resovoirs full.
2 Suggested Answers
  • 11800 Answers
SOURCE: J'ai une SUP 022 qui
During cleaning the lime is broken off the heater and water pump and its supposed to be pulverised and evacuated. In your case it most likely tore off in big chunks because the lime has been very thick (the cleaning hasn't been done at the regular intervals) so it has clogged the water pipes. The coffee machine will have to be completely dismantled and manually cleaned. This is a very complicated job, that you should leave to a Saeco repair shop. Or at least a good local repair shop. Get a quote before that, it will be expensive so be prepared.
Posted on Dec 21, 2010
My Keurig at work and home (both a little over 1 year old) wont pump the hot water through so therefore won't cycle even though it says it is brewing.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 29, 2011 | Microwave Ovens
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
I have three Mr. Coffee 4 cup coffee makers all bought at different times and they all leak water all over the counter. Can you help? Thanks, Ron
For what I remember, there is a small hose that runs on the bottom of the coffee maker. This streches and loses it's elasticity over time. I have cut it shorter, re-attached it, and then used a zip tie to keep it in place. Hope that helps!
Feb 09, 2011 | Microwave Ovens
How do you clean a Mr Coffee Model Number COF JWX27?
Most folks run white vinegar through one cycle to clean a coffee pot ... follow by one regular water cycle (no coffee).
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
Manual for Mr. Coffee SL13
mr. coffee hasnt added manual to thier library yet,youcan wait til they have it loaded or buy one and return it minus manual.May not be quite ethical but thats thier problem for not having it available
Oct 06, 2010 | Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
