Question about Pegasus Technologies Plumbing
My Pegasus Model FTV-100-01-15 leaks water from the very top of the unit just inside the lever assembly and has a constant (small) stream which floods my counter area. It started slowly and has increased with time. I suppose that the plastic round plug should be removed to make adjustments but I can not figure out how to get it off. How can I access the problem and what do I adjust to stop the leak? Thanks
keemo68
  • 1263 Answers
SOURCE: Leaking Kitchen Tap
yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
Posted on Sep 02, 2008
vegakitten20
  • 685 Answers
SOURCE: Water leaking from top of RO system.
i'm looking at the owners manual and it looks like its time for a new one not sure if you have the manual or nor here is the site i hope this will help you http://www.kenmorewater.com/website/customer-assist/manuals/625.347030.pdf
Posted on Nov 20, 2008
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 148 Answers
SOURCE: leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Posted on Dec 30, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
Not flushing, bowl will not fill up with water
Hi rjhfp
Check inside of the tank to make sure the connector from the handle of the flusher to the "flapper valve" is connected, to do this you have to remove the tank lid.
If it is connected then you have a different problem.
Sounds like you have trash in the valve inside of the "ballcock assembly"
The ballcock assembly is the part that lets the water into the tank, and the "flapper valve" is the part that allows the water to flush into the bowl...
Replace you ballcock assembly and it will solve your problems.
Free Answer...Please rate me
Apr 16, 2011 | Pegasus Technologies Two-Piece Round...
My Pegasus kitchen faucet leaks at the top, even when off. I'm not sure which model, it has one handle with a side spray. What do I do.
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Nov 29, 2010 | Pegasus Technologies Plumbing
My 6 yr old Maytag SAV5710AWW recently started leaking water from the bottom when it began the agitation cycle. When I opened up the front, I saw a single small stream of water coming from the top of what...
Sounds like you nailed it, the Tub Seal.
It can be a stream or an ocean, either way maytags do leak from that seal pretty often. Removal of the tub is your only option. The price is up to the tech, but this type of repair is considered to be a major fix, and is usually done in a shop.
Mar 18, 2010 | Maytag SAV5710 Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Looking for 3" flapper assembly for Pegasus 15 3/4"
go to Pegasus online with the model number which is inside the rear tank either on the underside of the lid or the interior upper wall of tank, its engraved so you have to look closly. give them that number and the will ship your part
Jul 07, 2009 | Pegasus Technologies Two-Piece Round...
is there an internal float that is stuck allowing overflow?
Nov 18, 2008 | Plumbing
Plumbing Logo
41 people viewed this question
Top Pegasus Technologies Plumbing Experts
Donni Steen
Don Numinen
Don Numinen
jdthefixer
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
