Question about Health & Beauty
I need instructions for use of everich yx 280b steam autoclave.
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Feb 16, 2014 | MTN Gearsmith New 1500w Commercial...
Short beeping with no error code
...no informative error? bacteriological filter? time for maintenance?
Jan 09, 2014 | Joyfay 12L Vacuum Steam Autoclave Medical...
Errors in euronda e5 autoclave
What is the alarm?
What phase of the cycle are you getting your alarm?
Oct 31, 2013 | Science & Laboratory
How do I replace cord for MTN Kitchenware model YX-280B 18L portable pressure steam sterilizer?
Good question! I have the same one and the cord just let out a lightening bolt and loud pop and blew away the outer covering. I cant find one either. Did you ever find one????
Oct 26, 2013 | Baby Care
Autoclave syl 280b
Replace the wire..
Oct 16, 2013 | Science & Laboratory
What are some different ways to remove air from the autoclave?
downward displacement, steam pulsing, vacuum pumps, superatmospheric cycles, subatmospheric cycles. http://en.wikipedia.org/wiki/Autoclave
Apr 29, 2013 | Science & Laboratory
How do autoclaves work?
Autoclaves sterilize devices by subjecting them to high pressure saturated steam at 121 degrees Celsius (250 degrees F) for at least 15 minutes
Jan 13, 2013 | Science & Laboratory
Health & Beauty Logo
149 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
