Question about Panasonic NN-T964SF Microwave Oven
Oven will not turn on. There is power at the outlet
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 13, 2010
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    No power to microwave
    Hello
    Check the Power Cord
    Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
    Switch the Outlet on
    Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
    Reset the Oven
    Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
    Check the Fuses and Breakers
    See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
    Oct 04, 2011 | Microwave Ovens
    FAILURE TO TURN ON. Outlet power is ok.
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    heatman101
    Nov 14, 2010 | GE JVM1490 Convection/Microwave Oven
    Power quite one day it lost power like curcuit broke there is power to the outlet
    If there was a power outage, and then your microwave oven never came back on. Then it could be a possible fuse problem. If the circuit breaker had tripped, then after you turned off the cir. brkr. and turned it back on, then everything should've worked fine. Again, I would lean towards a blown fuse in your microwave. Now you're saying there's power to the outlet, and it still won't go on? Then my easy solution would be to plug it into another outlet, and try it again. Your problem could be that plug. After doing everything I just suggested, at any time did you get a digital readout on your time display in the upper right hand corner of the oven. Basically, is there any lights on at all when you're plugged into the wall. If not, then the problem is in the microwave itself! It could be just as simple as a blown fuse, but I would like you to try these other alternatives first. Feel free to contact me again if these don't work. Good Luck, and I hope I've helped you some. Let me know, Jim
    Apr 06, 2010 | General Electric Microwave Oven
    I have a Kenmore Microwave Oven - Elite Series - only about 3 years old, keeps blowing fuses - any advice on what might be the problem? I think the first fuse blew during a power outage, not sure if that...
    make sure you have the oven plugged into a designated outlet...what I mean by that is...the outlet your plugging your oven into must be wired right to the fuse box by itself...because the oven will take most of the power from that one fuse for itself...also make sure the fuse is rated for what the oven needs....on the back of the oven, it will tell you how much current it takes...(???Amps), if it says 12 amps for example...the fuse should be 15 amps...if its lower that 12...it will keep blowing....if all of what I said check out then your oven has developed a short circuit...most likely the high voltage diode or magnetron....have it serviced....
    Jul 25, 2009 | Microwave Ovens
    The power is not on anymore.
    It ended up being just a $2.50 fuse. Thats all. Glad I didn't have to pay someone $80 to walk through the door and tell me that. Don't you hate that!
    Mar 21, 2009 | Whirlpool GH5184XPQ Microwave Oven
    Panasonic NN-T964SF Microwave Oven Logo
    80 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jerry Greenberg
    Jerry Greenberg
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
