Question about Kenmore Ovens
How do you replace the bottom heating element in the Kenmore oven?
    President:
  • 1,430 Answers
Here is a link that should help
Replacing a oven heating element
You can also menter in your model # for diagrams and illustrations of your specific model.
Posted on Oct 13, 2010
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Bake element not working
You will need to replace the oven control ERC
Jan 25, 2014 | Kenmore Ovens
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Kenmore C970-645121
The replacement element may be no good
Apr 27, 2013 | Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom Coil on Oven not Heating Up
yes it is most likely the element (coil) itself burnt out. inexpensive and easy to replace.
Jun 28, 2008 | Kenmore Ovens
Ovens Logo
91 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
