Question about RCA P61960 61" Rear Projection Television
Bad convergance picture is warped and blury on both sides of screen and top and bottom
  • jkclay841 May 11, 2010
    i would like to buy your tv for parts if u would be interested in selling thank u please let me no soon
I'm not positive this will work, but your problem sounds like mine. My Guru and I seem to think the screen itself is a little warped. He suggested the outside layer of the screen should be replaced with 1/16" plexi. He said he did it to his projection and it fixed his problem, however you will lose aniglare if you switch to plexi.
Posted on Jul 24, 2009
    Problem Solver:
  • 5 Answers
Where about do you live? If you can't fix would you be interested in selling it for parts? thanks and let me know
Posted on Jun 10, 2008
Picture is off the top of the screen everytime it is turned on. If you turn it on and off several times(3-13) it will become watchable. Sometimes it is off the bottom, or both sides are concave. Or it will...
Its a rather old set to be fixing, if off at top or bottom=vertical deflection problem, if sides are concave pin amp circuit---the fact you can turn it on/off several times etc suggests to me maybe bad solder connections somewhere in those circuits.
AS old as this set is keep in mind a lot of the parts for it are no longer available so be careful about spending a ton of money to fix it.
Dec 14, 2012 | Sony KP-61V35 61 in. Rear Projection...
Curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 04, 2009 | Samsung HCN4727W 47" Rear Projection...
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Television picture
Is it bouncing in and out or just blury? If its bouncing in and out you can get a repair kit on www.magnavoxhelp.com. If its blury my guess is that the convergence IC's STK-392-120 are bad.
Aug 04, 2008 | Philips 60PP9202 60" Rear Projection...
Projected image is too large for screen
Good Day Brian;
The warped, too large picture is the same problem, the TV has a convergence problem. ln today's electronics the first thing that should be done on any electronic device is to, reset, unplug TV from the a/c outlet for at least 4-5 minutes then plug back in. If no fix; Your TV has a circuit problem. RCA has three common problems that could cause this condition; the most common is a fuse near the fly-back, IH-VT, the convergence power board or the signal board.
Always, call a factory authorized service dealer if you are not familiar with repairing electronic equipment that contain HIGH VOLTAGE, just for your own safety.
Good Luck, Big Irish.
Jun 21, 2008 | RCA Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Hitachi 51f500(flicker+warp)
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Jan 23, 2007 | Hitachi 51F500 51" Rear Projection...
RCA P61960 61" Rear Projection Television Logo
185 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
