Question about Dryers
The tumble dryer has become very noisy when warmed up almost lije a screaming noise
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 13, 2010
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Bosch WTA2000 tumble dryer motor turns weakly without the belt.
The brushes in the motor are probably shot. Good luck in finding those though, best to just replace the motor.
Dec 09, 2013 | Bosch Axxis WTA 3510 Electric Dryer
I have an indesit IS70 SC tumble dryer which is very noisy. The noise appears to be coming from the air intake fan and sounds a bit like a piece of cardboard against bicycle wheel spokes. Any ideas?
Dryers are not hard to take apart.
There is possible something caught inbehind things.
Make sure to unplug the dryer first. Then proceed to take it apart carefully noteing thing as you do it, so that you can reasseblem
Jan 12, 2013 | Indesit IS70C Electric Dryer
Our white knight 77aw tumble dryer is very noisy.....is there anything we can do to reduce it?
heatman101
Jul 26, 2011 | Dryers
My hotpoint vtdoo tumble dryer is making a screaming noise and belt is still inplace and turning.
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Sep 07, 2010 | Hotpoint Dryers
Tumble dryer works ok but its really really noisy.
Sounds like you have a bad drum bearing. It's seems loud because the clothes drum aplifies the noise. Depending how old it is will determine if repairing is worth the cost. Once you have decided that, replace the drum belt and check all bearings including motor. Clean out all lint which can become a fire hazard.
Oct 15, 2009 | Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Oct 11, 2008 | Kenmore Dryers
Zanussi TDE4234W Tumble drier noise
Probably the gliders is worn.
Jan 31, 2008 | Dryers
My dryer
I have a WTL5400 screaming at me, so my Husband has taken the side and back panels off to investigate,and the noise was made by the air outlet plastic fan which spins when the tumble dryer is turning, this plastic fan thing was wibbly wobbly and the nut wouldn't tighten up. He has put in a couple of different size washers and tighten up the nut and hey presto no noise.
Oct 16, 2007 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
