Question about Sony PS-LX250H Turntable
I have the sony record player above, and when I was moving I put it on its side and the belt came off. Now I cant figure out how to put it back on. Help ?
  • 44 Answers
The Operating Instructions link on this page:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=PS-LX250H
appears to give guidance on connecting the belt. Any use?
Posted on Oct 13, 2010
I have a Sony PS-LX250H that was put into storage and moved twice while I was in transit between residences. Since I got to my new place I haven't been able to get it to work at all even after rep
hi
check the belt it might be loose...
elasticity of the belt is ... no more :(
try turning the plate by your hand and see what happens
Good Luck
May 09, 2017 | Sony PS-LX250H Turntable
I have a john deere sabre 15.5/42 and cant figure out how to put the deck belt back on
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Aug 28, 2009 | Garden
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
How do i watch the dvd
You should finilize DVD before playing back in dvd player.
Jun 01, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Record player
does the plastic mat lift up? if so there should be a hole where it can be slipped back on , if it fell off more than likely you will need to replace it and the table should pop off by lifting it up.
Jan 26, 2008 | Sony PS-LX250H Turntable
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Sony PS-LX250H Turntable Logo
222 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
