Question about LG Cell Phones
Dropped cell phone in water. have removed battery and let dry out for 4 days. phone now works (can make calls, receive calls, keyboard lights up) except no display is available. any suggestions?
  • 31 Answers
Probably need to disassemble to find the cable that runs to the screen, and it may need cleaned at the connection. If this doesn't work then chances are you fried the video portion of circuit board, or perhaps the screen itself. Hope this helps.
Posted on Oct 13, 2010
I dropped my samsung intensity in water and i took it out right away and dried to dry it with a hair blower will that damage it more ?
Hi
remove the battery from the phone first.
don't attach charger to the phone to charg th battery.
its good to dry the phone with th hair blower but don't do it for a long time.If phone became to hot then that will damge th mother board.put your phone in a bowl of rice for 3-4 days that will help remove moisture and water from your phone.thank you.
Sep 22, 2011 | Samsung SCH-U450 Cell Phone
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
I have dropped my E5 into the bath
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front of a warm fan heater for several hours then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
Jun 27, 2011 | Nokia E5 Cell Phone
I have an HTC (HD2) cell phone that fell in water... it still works but the lcd/screen does not work... I can only receive calls.. What should I do???
I'm sure by now you have gotten the problem resolved with a replacement phone. If not, drop the phone into a bag of dry white rice. Remove the battery and leave the cover off to expedite the drying.
DO NOT PUT THE PHONE IN THE MICROWAVE OR OVEN!!!!
Apr 26, 2011 | HTC HD2 Smartphone
Assalam o alaikum. my cell drop into water tommorrow next day working right.but now many of buttons are not working??? what i can do for this? Thanks
Number 1 rule if your phone gets wet... DO NOT turn it on.
Remove the battery from the phone. get a small ziploc freezer bag place phone in bag pour uncooked grains of rice into bag. Enough to cover phone completely. Close bag. Let it sit for at least 2 days.
This is to absorb all the moisture from the phone. Remove phone, insert battery and try using it. It may work. But you need to wait until your phone is completely dry before attempting to use it.
Mar 09, 2011 | Nokia 1208 Cellular Phone
How to take apart the LG Versa to dry out moisture behind the touch screen. It went through the washing machine, appears to work otherwise though
I would not try and remove any backing or covers off cell phones. I dropped my cell in the lake a couple of years ago. I took the battery out and laid the phoone and battery on my dash for a couple of days and this baked out all the moisture. the phone still works today!!
Oct 26, 2009 | LG Cell Phones
MOTO Q DROPPED IN WATER
my friend did this. he just went to his insurence company and got a new one. but if you dont have insurence there is no way to fix it(that i know of) sorry
Nov 27, 2007 | Motorola Mobility L6 Cellular Phone
V3 got wet
sorry to say this but a wet phone is ruined. You will have to take it to a tech at your phone server. They will either repair it or you will have to get another one. Water and phones do not go together at all. Sux.
Aug 20, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
41 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
